If this is the 3-in-1 air conditioner, then you have two options:
1- do you see two drain outlets on the back? one is at the very bottom and has a removable plug and the second should be about half way down also with a removable plug. This air conditioner has a small non-removable tank that will fill up and a red light on the panel will light up and the machine will switch to FAN mode when full. Then you have to roll the machine to a drain and unplug the bottom plug to let it drain out. Not resonable.Probably good for a basement with a drain in the floor, but not on the main floor or 2nd storey floor.
2nd method is to unplug the top drain (Keep the bottom drain plugged) , attach the plastic hose that the machine came with to this drain, find a bucket that is at the same height or below the top drain and let the water drain into the bucket. Then when it gets about 3/4 of the way full, empty the bucket.This way the airconditioner mode and the humidifier mode will work continously.
This is the way this type of air conditioner is made.
Hope that helps
Do you have to add any solutions to this air conditioner. The Uberhause 3 in 1 model.
