Question about Paradigm PS 1200 Speaker
Dear Sir I need the value for resistor R90 , R91, for Paradigm PS 1200a Best Regards Ruben
Posted by mre9 on
jtelelec
    New Friend:
Hi Ruben, the value of R90 and R91 are 180ohm
Cheers
Joe
Posted on Oct 24, 2012
R91 value in dc18rRC T Makita charger r91 is burnt out do you know what the value is. See the board in the left corner
Most likely replacing that Resistor is not the only problem, do you know how to replace surface mount components?
I can look on a know good unit and see if there is a value or measure it. Surface mount components are not sold like regular electronic parts were.
Radio Shack Multimeter, 22-168a, shunt resistor value????
Go to the Radio Shack site and you may with the model number find a schematic or you can email/contact them for the value of the resistor.
I predict it is a precision value and type you will have to get from them if available.
PS: you posted in wrong catagory as this is TV section.
3helpful
Our ten year old paradigm ps 1200 subwoofer does not power up, although it is plugged in and properly connected to the receiver. Why is this? Is it a lost cause?
Disconnect the power, pull the amplifier out by undoing the screws that hold it in.
When you pull it out, look closely towards the top there is a little 1.8A fuse. It probably has blown.
Replace that and you should be back in business.
Blown resistor and IC
R91 is a 1K Ohm
M1 is FSDM0356
2answers
Please help me about my power supply it is compaq (24 pins)model no. ps-7231-6cf..the resistor is burned..i dont know color code or the value number of my resistor..only i know is in the circuit of my...
sir
pls dont try it your self. you should better call a repairman for it. He will if possible repair it or you would have to buy a new one.
thankyou for using fixya
dont forget to rate the solution
2helpful
2answers
PAradigm ps-1000 subwoofer
It turns out its most likely one of the resistors on the PCB on the amplifier plate.
My uncle has had the same problem and managed to replace the resistor and its working as normal now.
Paradigm PS 1200 Speaker Logo
Top Paradigm Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
