Delta Woodworking Delta Rockwell 14 Inch Wood/metal Band Saw Manual Logo
Posted on Jul 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need service and repair manual for rockwell ban saw #28-243 model 14
efs_perpends
Level 3:
President:
  • Master 1,997 Answers
  • Posted on Aug 02, 2011
efs_perpends
Master
Level 3:
President:
Answers
1997
Questions
Helped
777324
Points
5779
Please check the publication reprints available from this website, in particular this link.
They are owner's manuals rather than service manuals, but include exploded parts views and lists and most required instructions.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
How much does a rockwell 14" band saw cost?
It has been discontinued by Delta. It would be hard to find replacement parts for this band saw. I think Rockwell 28-20C would cost $100-200.
Where do I find a guide rail for a Rockwell 4500 circular saw?
If I'm not mistaken, that model saw is already discontinued. I suggest you call or email Tool Parts Direct or Delta. I only have band saw machine, I'm thankful that bandsawparts.com makes aftermarket parts for all brands of band saw.
1helpful
3answers
I just purchased a used Rockwell bandsaw. I need
Ok so you understand that Rockwell became Delta, or was it the other way round?? Either case the best source of manuals for these much loved machines is over at Old Wood Working Machines:
http://www.owwm.com/mfgindex/detail.aspx?id=698&tab=3
You should find your model.. 14" Delta doesn't really pin it down too exactly. The model number should be on the warning plate.
2helpful
Manual or info on a rockwell 28380 14" band saw
I can't find one for the exact model number you have, but there are a lot of manuals for the same era bandsaws available as PDF downloads at this site. Perhaps another manual for a similar machine will help answer most of your questions, in lieu of the correct one...
Have a look around there, though, at both the Delta and Rockwell listings, as I just made a quick look to find yours and there might be something there somewhere.
Manual,fence and rail
The manual doesn't seem to be available online at the moment. There's a parts diagram, if that's helpful, or perhaps you can find an alternate site that provides instruction manuals. See this link, in any event.
Otherwise, you might check Woodworker's supply (woodworker.com) for the accessory fence and rail. They carry genuine Delta parts, which should fit your old Rockwell, as well as some aftermarket fences and guides that will usually adapt easily to fit a 14" bandsaw. The 14" Rockwell is one of the industry standards, and many woodworker catalogs carry fences that will bolt on with a minimum of fuss.
I recommend you do a web search on "14" bandsaw fence", and browse the results. You may even find something used to suit your needs.
Good luck, and let us know if this solves your problem or we can provide any further information!
Manual & fence system
I would contact the nearest Rockler woodworking store. they have or can get it for you.
please mark this as a fixya!
Wood like to clean & update my rockwell model 14 band saw need a download of this saw
try there web sight, if I'm not mistaken, Delta bought out rockwell and they should be able to help. I had an old rockwell table saw and the man shaft that the blade attached to was missing.I contacted delta with the model number of the saw and they faxed me a blue print of the shaft and we machined a new one and the saw still works great.
Top Delta Woodworking Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Delta Woodworking Saw Expert? Answer questions, earn points and help others
