Kenmore Elite HE5t Washer Logo
Posted on Jul 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I keep getting a SUD error, I have stopped the cycle and reset by unpluging the washer, it keeps showing the SUD error. What should I do?
Anonymous
Level 3:
President:
  • Master 1,554 Answers
  • Posted on Jul 20, 2011
Anonymous
Master
Level 3:
President:
Answers
1554
Questions
0
Helped
611840
Points
4917
This code indicates that an apparent sudsing condition is detected. It happens when a non-HE detergent is used. Run a cycle without detergent or allow the machine to fill then drain it to make sure suds are removed. The problem is in draining if the code still flashes even no detergent is used.
Unplug the machine or disconnect power then remove the three screws attaching the bottom of the lower front access panel and pull the panel down and off. Once the panel is off, you'll find the drain filter attached to the drain pump.
Place a container or a piece of towel underneath the filter to catch spillage. You may need to drain the water from the machine by putting the end of the drain hose over a container on the floor. Position the container as low as possible to extract as much water.
Remove the filter by turning the knob counterclockwise and clean it. Also take a moment to inspect the drain pump impeller by reaching it in with your finger and turning it. The impeller should turn freely. Otherwise, replace the drain pump.
This Kenmore machine is made by Whirlpool and therefore troubleshooting is basically the same. Click on link below for more detailed drain problem troubleshooting.
Drain Problem Troubleshooting on Whirlpool-made Front Load Washing Machines
I keep getting error codes on washer and will not continue the cycle
That code in most cases means you have a bad pressure switch. It is generally $99.00 (approx) for the cost of the part.
3helpful
2answers
Error code F 35 and SUD code
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
1helpful
Kenmore Elite HE4t stopping in mid cycle with F abd DL errors
See Phoebe 112 latest solution! This is a common problem with these washers. For a quick fix you can usually get it going again by unplugging it for 30 mins. so the computer will reset. You will hear a slight buzzing noise when it resets. If it keeps doing it, go to the comment for Feb. 14, 2009 and try that if you are handy. Unplug the machine before doing any of this as with any machine that is electric or you will probably get the shock of your life.
2helpful
Whirlpool duet washer flashing sud then f21 ????????
The "SUD" error is in direct relationship the other error code. "F21" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If something is preventing water from pumping through the drain pump, you will often get a "SUD" error as air is developed in the pump. Make sure you double check all the drain lines as well.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
sure the pump is running.
4. Check the drain pump filter for foreign objects.
Have "sud" code and"f 02" code
I don't have a solution but I feel your pain.
I had an F02 error flashing so I got brave and took off the front panel and opened up the drain thing. What a mess! Water everywhere and OMG,the filter was caked with goop, a popsicle stick and a piece of metal.
I still get a Sud error so I am having the Sears guy out in the morning.
1helpful
Kenmore Elite HE4t Washer
"F02" and/or "Sud" error are directly related to a common problem in this case. You have something clogging your drain line and/or drain pump. The error will not go away until you clear the problem. The following links explain how:
http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In some cases, the drain pump may require replacment. If something has been lodged in the pump reservoir for any period of time, sometimes the pump impeller can become damaged to the point where it does not pump water. Replacment pumps can be found at searspartsdirect.com or repairclinic.com. Just type in your model number inthe search menu. I hope this helps you resolve your problem and that you do not require parts. Let me know if you require additional assistance.
135helpful
8answers
Whirlpool Duet Washer-error code "sud"
Just take off the bottom kickplate (3 screws on the bottom). You'll see the pump front and center. Twist the front face of the pum slowly to the left. All the trapped water will flow right out towards you. There could be a sock or some other debris there. Unclog, screw that faceplate back in and start it up.
Error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Alexander
vince
