If it aggitates, then the tranny and motor coupling is ok. the drive assembly is bad. nintey perent of the no spin problems is motor coupling problem. But since yours will aggitate, then the coupling is fine.
Check your motor drive coupler. Tilt washer back against wall and look between motor and transmission . You will see a rubber grommet and two plastic couplers on each end of rubber , They may appear broken or you will see rubber shavings under washer.
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here http://www.repairclinic.com/0080.asp Catriver...post back
