Question about Hotpoint Refrigerators
I bought the hotpoint ice diamond fridge freezer the number on the outside of fridge is RFA 52 july 2010 i have had the thermostat on number 2 but the milk was iced up this morning so i have it on number 1 now could you tell me what the problem is please. thank you. jean
Posted by jeanneary9 on
deton8 von Splosion
  • Hotpoint Master
  • 3,339 Answers
Hello Jeanneary9,
Proper AIR CIRCULATION is critical to the
proper operation of the unit as a whole...
(I prefer my milk ICY cold... but fluid).
First thing to do is inventory your air vents
inside the FREEZER area... to ASSURE that
NONE are blocked (from open)...
Then inspect the air vent INTO the refrigerator
area that NONE of those are blocked (closed)
Most modern refrigerators give preference
to the milk storage shelf...
ELSE...
(first try a full 3 day DEFROST... (unloaded
with doors wide open... Then set to original settings
(three more days)))...
Only then you are looking at (sorting) a
DEFECTIVE thermostat...!!
I use (rather inexpensive) TAYLOR ($6 - USA)
refrigerator thermometers to regulate temperatures...
and STAY AWAY from "adjusting" as much as
Possible... as it can take UP TO 3 days (72 hours)
for the refrigerator to stabilize...
Hope this helps
Carnac the Magnificent
Posted on Jan 29, 2018
5 Related Answers
bomark2002
Mark Bowens
  • 187 Answers
SOURCE: Freezer Icing Up
Try contacting the hotline again and ask them if the freezer has a frost sensor on it. If it does, the sensor is not kicking the thermostat to allow for the unit to defrost.
Posted on Oct 21, 2007
Robert Hirst
  • 833 Answers
SOURCE: Hotpoint Ice diamond fridge freezer both green & red lights on.?
bulmer...it takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you do...be sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit in...watch out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
Posted on Dec 18, 2007
Anonymous
SOURCE: red and green light on
your filter needs to be changed when it is red
Posted on Apr 17, 2008
douglas smith
  • 1462 Answers
SOURCE: Danfoss compressor in Hotpoint RFA
assuming the relay is ok and relay is unlikely to fail in 18 months, i'm afraid you have a compressor fault
Posted on Jul 06, 2008
douglas smith
  • 1462 Answers
SOURCE: Hotpoint fridge freezer RFA 06. Freezer OK, but Fridge not working after drain unblocked.
fault is nothing to with unblocking drain hole
Posted on Sep 30, 2008
Hotpoint HTR17BBRFRWW top freezer does real cold but bottom fridge stays at 52 or above. Coils clean and gaskets good, unit level and compressor runs quiet. What is obstruction between freezer and f
http://www.partselect.com/Schematics/GE/00113789i02.gif
look at number 304. Ice more than likely has formed and not letting air flow from the freezer to the fridge.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 03, 2012 | Hotpoint Refrigerators
I need to replace the rubber seal on my Hotpoint ice diamond freezer door I can't find any fixing screws on the inner door panel can I assume then that the panel clips on.
Me too, I have a Hotpoint Iced Diamond Under counter fridge that needs a new seal and i also cant see any fixings to remove it. I did read somewhere that you can't replace them you need to buy a complete new door.
Dec 14, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Operating instruction for iced diamond rfa 51p
high temp light on and not cooling in either freezer or fridge RFA51P ?
Mar 14, 2010 | Hotpoint Refrigerators
Freezer switching off on Hotpoint Iced Diamond Fridge Freezer
home refrigerators are not dsigned to work in areas where the temps will drop below about 45 f to my knowledge there is no way to help wiht this problem. Thx peyton
Jan 29, 2009 | Refrigerators
Frezer does not seem to be working in the cold
s it should the ambient temperatures that you said are way to cold to expect the freezer to operate properly. move it indoors and or contact the manufacture and see if the have a kit to put on the unit to work properly.
Jan 10, 2009 | Freezers
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Refrigerators Logo
35 people viewed this question
Top Hotpoint Refrigerators Experts
jdthefixer
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
