Question about Bosch Dishwashers
Bosch dishwasher does not fill with water - Bosch Dishwashers
Posted by ogorman_jame on
Daniel Scott
  • 4,323 Answers
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jul 21, 2011
5 Related Answers
Anonymous
SOURCE: Bosch Dishwasher not letting in water
The float switch may be stuck in the up position which shuts the fill solonoid valve off. you should be able to find the float switch under the lower dish basket.
Posted on Jan 14, 2008
douglas smith
  • 1462 Answers
SOURCE: My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Posted on Nov 26, 2008
Anonymous
  • 236 Answers
SOURCE: BOSCH DISHWASHER SMS63E09GB FLASHING E 15 CHECK WATER
it may be either the water meter tank on the l/h side or front water feed hose is blocked with food debris.
Posted on Mar 13, 2009
Anonymous
SOURCE: Bosch SHU 4000 series dishwasher; Water keeps on filling
Follow-up: I was able to fix the problem on Bosch model # SHU 4002UC. Purchased water inlet valve (part number 425458) from Sears Parts Center. I required the Sears unit number from the original invoice as Sears computer system apparently cannot identify the Bosch model number. The valve is as described by meyerjr above; however it is located at the bottom front of the machine so could be replaced (not so easily) without removing the machine. Cost of part was $30.50 Cdn including tax.
lwou
Posted on Apr 20, 2009
bosch guru
  • 457 Answers
SOURCE: My bosch dishwasher will not fill with water. I
the unit is going into drain mode. check your hose for leaks. when water leks in the base of the unit the float switch is activated and the unit will stay in drain mode until the water is removed. check float by removing side panel and look into bottom base for water.
Posted on Feb 27, 2010
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
Have bosch sgs 6312gb it's not filling with water in machine
If it works when water is added the the over flow switch is ok
Here is the diagnostics guide Bosch dishwasher service guide
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 23, 2011 | Bosch Dishwashers
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
Won't fill with water
Bosch dishwashers typically have flood sensors in the bottom, below the motor. If there is still water in the pan the machine will not fill with water and only try to run the drain pump. Be sure there is no water in the dishwasher pan
Dec 02, 2017 | Bosch Evolution 800 SHE68M05UC Stainless...
BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
Jan 05, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher
i know this sounds daft but --
turn off water. disconnect fill hose from water supply. wait 5 seconds and reconnect fill hose then try it out
Oct 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
917 people viewed this question
Top Bosch Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Mike
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
