Unfortunately it seems you USB drive has had a critical failure. If it is less than 1 year old, you can contact the manufacturer for a replacement. USB drives, like any other drive, should always be backed up. If you would be lost or dismayed by loosing the information, back it up somewhere and maybe even two or three somewheres.
click start control panel administrive tools computer
management device manager scroll down universal serial bus controllers you
could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to
fix the problem
check the USB leads that attach to the motherboard usually
red white green black make sure they are securely seated and have no dust build
up on them dust will cause static and a lot of unforeseen problems for a
computer and its parts:
click start control panel administrive tools ,computer
management ,device manager look through all of your devices if you see a yellow
question mark?or exclamation mark ! or red x
right click to reinstall drivers:
hope this will help you
