Question about Nikon COOLPIX L12 Digital Camera
The lens on my coolpix l12 keeps getting stuck and the shutter cover will not close
Posted by bagnalls_pou on
Ramkumar
    New Friend:
Posted on Nov 30, 2011
The screen unexpectedly went blank and black....apart from camera info symbols..all pictures taken now are black..... pictures taken before can be seen on screen,....lens moves in and out ok
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 04, 2011 | Nikon COOLPIX S220 Digital Camera
My Nikon Coolpix L12 will power on but won't take a photo. There are no error messages on the screen. The lens will extend and retract. The zoom works. The shutter release button depresses but will not...
Well, seems like a camera failure to me,actually the processor inside the boards is wrong, maybe your product is a failure ones, I think it's better for you find the dealer or service center to solve this problem.
But, you can try remove the battery off from the camera, and let the camera without it for about 2 hours, then try put it on again, maybe this trick can help you!!!
Dec 09, 2009 | Nikon COOLPIX L12 Digital Camera
My camera nikon coolpix l12 keeps saying lens error,what should i do
This is a serious problem with Coolpix cameras. If it is still under warranty then take it to a warranty repair facility for Nikon.
If it is not under warranty you could try removing the battery for a few minutes, put it back in and try the camera again. As a last resort before tossing the camera out.....CAUTION DOING THE FOLLOWING MAY RESULT IN PERMANENT DAMAGE TO YOUR CAMERA, DO THESE AT YOUR OWN RISK.... Other remedies that may work would be to gently tap on the sides of the camera to see if you lens may be stuck in a certain position. Or, you could gently and slightly twist the lens back and forth.... VERY GENTLY though. This may free up the lens and allow it to work.
I hope some of this works for you and good luck.
Nov 14, 2009 | Nikon COOLPIX L12 Digital Camera
My screen is black or blank
I think you mean your automatic lens cover opens. A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Feb 23, 2009 | Nikon COOLPIX L18 Digital Camera
Lens Error, Restart
Nikon System error help????
Sep 05, 2008 | Nikon COOLPIX L12 Digital Camera
Nikon coolpix l12 lens error
Dear All, Looking at other threads this seems a standard fault for many brands. I know the dreaded 'lens error' is a recognised Nikon fault.
I had the same problem with a Nikon Coolpix L1; lens would shuttle in and out rather woriedly and then get stage fright and freeze, hiding behind a lens error tag.
The solution came from a similar site to this and listed at least ten happy punters who tried it and found it worked, so, brace yerselfs....
Put a paperback book on decent sort of a table and slam the flat base of the camera down onto it as hard as you dare. If you slam and hold firm to the book it seems to give better shock without having to belt the poor thing to hell.
Worked first time for me. Not a cure, though. You'll have to repeat it every few months perhaps.
I suppose your camera may explode during the process; I decided mine was unusable as it was and so I'd nothing to lose.
If you break your wrist change to the other hand and don't slam so hard this time!!!
Before that I found some correlation between battery type, charge and lens function but the book bash was an instant cure.
Do let me know of any success
Apr 12, 2008 | Nikon COOLPIX L12 Digital Camera
Battery Problem
These cameras have a internal battery that holds data for the camera to keep its settings. These batteries can be replaced but the camera has to be disassimboled to change it they should be able to be changed at a local camera shop pretty cheap.
Mar 21, 2008 | Nikon COOLPIX L12 Digital Camera
Black Lcd and pictures.
The problem you are experiencing is due to the shutter being stuck closed. Normally the shutter is kept open while you compose the image, and then when you push the button it closes and the CCD records what it was seeing at that moment. When the shutter is stuck the image is blocked from reaching the CCD at all times so you can see nothing. Unfortunately the shutter is a tiny delicate component buried deep within the lens assembly and is not accessible without complete disassembly. I would suggest finding a repair center to ship the camera to, or replacing the camera. I would definitely not _gently_ tap the camera on a hard surface to possibly dislodge a slightly stuck shutter blade. This could easily cause further damage to the camera. However, you are not me. ;) David Millier Advance Camera Repair
Feb 22, 2007 | Nikon Coolpix S1 Digital Camera
Nikon COOLPIX  L12 Digital Camera Logo
238 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
