This is from Nintendo support's website
Error Code: 52130
Was this information helpful?
The Wii is unable to connect to the Internet
Likely cause: The wireless router is incorrectly connected, or the Wii console will need a DNS manually entered.
How to fix: Check the way your router is connected; manually assign a DNS to the Wii.
- Check the connections to your wireless router:
Even if you are able to get a working Internet connection to your
computer through the wireless router, if it is not properly connected to
the modem, the Wii and other devices may not be able to use it.
- Most routers have five (5) ports on the
back. Typically there is a set of four, with a single port either
farther away from the rest, or separated with a different color border
or line. This single port is often labeled "Internet" or "INT." Make
sure the cable coming out of your modem is plugged directly into this
"Internet" port, and not into one of the other four that are grouped
together.
- Manually change your Wii console's DNS settings. To do this, follow these steps:
- Access the Wii system settings (how to), and use the right arrow twice and select "Internet."
- Select "Connection Settings," and choose the connection file (1, 2, or 3) that are you are currently using.
- Select "Change settings" and click the right arrow 3 times to reach "Auto-Obtain DNS."
- Select "No," and choose "Advanced Settings."
- Click into the "Primary DNS" field and enter: 8.8.8.8
- Click into the "Secondary DNS" field and enter: 8.8.4.4
Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service.
If you prefer to not use this service, doing an Internet search for
"public DNS" will provide you with several other options you can use.
- Select "Confirm," and then "Save."
- Select "OK" to start the connection test. Once the test finishes, try to download the update again.
If you are still getting this error code after trying the steps above, please call 1-800-255-3700 for further assistance.
Good luck
