You can get replacement ends at any parts store. To install them, disconnect the cables from the battery and cut the original end off. Strip back about half an inch of insulation and put the end under the ******** the new end and tighten the strap. Make sure you mark the wires so you know which is which and put back all attached wires. When disconnecting a battery always remove the (-) first. When putting them back on, attach (+) first. That lessens the possibility of shorting anything out. Never allow anything metal to touch both terminals on the battery at the same time
