Question about LG L194WT 19" LCD Monitor
Hi, I turned my computer and monitor off as I normally do last night and when I came downstairs this morning to turn my computer and monitor on, my monitor didn't turn on. I pressed the power button on the back of it and the light on the lower right corner did not turn on. I tried holding down the power button, but nothing happened. I tried swapping the cable with on which I knew for sure worked, and still the monitor wouldn't turn on. My monitor is an LG L194WT Flatron. Is there anyway which you could help me sort this out? Thank you
  • 922 Answers
You need your monitor repaired or replaced.
Unlike a computer, there is not much troubleshooting beyond making sure it is plugged into a live outlet and turned on which you did already.
Posted on Jul 19, 2011
    Brigadier General:
  • 10,406 Answers
Take the LCD to a qualified TV/video technician, for professional trouble-shooting and repair.
  • yooni Aug 20, 2011
    Same problem here, so I took my Monitor to LG Service Center, First they plug the power cable .... it turn ON.. they said maybe my cable... so went back home, I replace my cable power.. but still wont On..... WTF..?
6ya staff
SOURCE:
My monitor was fine last night, when i woke up this morning it would not come on, the blue light is flashing, help
Press and hold the button, until the monitor turns itself off.
Then, turn it on, and hope that it works correctly.
Aug 21, 2010 | Proview PL926WBi 19" LCD Monitor
Hi, my 713N monitor worked last night. i turned
That shows you that the problem is not your monitor
but your operating system is not booting or is hung
turn off your computer & restart pressing F2 as soon as it starts to boot up select open in last known configurationto see if the O/System will know boot up
If this Fails &you are not a experienced enough to do a repair sequence from your O/S disc .Reinstall your O/System
Dec 03, 2009 | Office Equipment & Supplies
One of 2 Lennox AC units not working well.
check the filters if it needs cleaning....or check the refrigerant level if it is below normal
Aug 11, 2009 | Heating & Cooling
3 inches of black on both sides of my monitor
I have seen this when using HDMI cables from the computer side.. The TV has a resolution that is not always full screen with TV shows. There is a setting that allows you to "zoom". My TV has 4 settings: normal, stretch and crop, stretch left and right, stretch and pinch (shrug).
Jul 07, 2009 | Hansol (720ESB) (Black, Silver) 17 in.CRT...
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Turns off after ONE second
like i put in another solution, this is probably the capacitors on the power board in the screen :)
easy fix if your okay with opening it and you can solder :)
theres 4-8 capacitors usually on the board, check if any have residue on them, or are fat (not normal cylinder)
Feb 03, 2009 | Westinghouse LCM-19v1 Monitor
Samsung 206bw Monitor Flashes/Flickers on and off
Set the Hrts to 60 in Display Properties in control panel
Jan 14, 2009 | Samsung 206BW Monitor
LG L194WT 19" LCD Monitor Logo
380 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
