SOURCE: my dell dimensions 4600 will not boot
Dont worry.This can be resolved.Goto the BIOS by tapping the F2 key on the restart -Goto the option which says Maintainence>>Event log>>Clear all even logs -Now press F10 to save and exit or press the ESC key just once and Select SAVE and EXIT
SOURCE: Alert! previous attempts at booting this system
I'm not sure right off hand what the WRIT means. But other articles online seem to think that you should hit F2 at boot and check the Boot Order. One guy set it to CD and booted a CD (a bootable one) fine. I would make sure it set to the first Hard Drive. He also said something about: went to the "event log" section and cleared the last event (actually the only one showing). I saved the settings, then booted up again and this time it booted up normally.
* Anyway new hardware external or internal would be 1st suspect in this kind of thing. One person had problems after adding a new printer that had a memory card in it. Apparently the Dell tried to boot from the memory card.
SOURCE: when booting my dell optiplex dimension 270 i get an alert message of checkpoint [krst]
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
