Knowing your make and model would help. Here are some generic instructions for finding your leak, please post a comment if you require further assistance:
There are an
huge number of things that might make a machine do this and because there is
usually a framework at the base of most machines, the point that the water
leaks OUT and the place the water is coming from can often be vastly different,
so I will cover what I suspect are the main culprits.
Before you
start, check the tub shield gasket (This is the big grey rubber between the
door hole and the drum. Push the drum backwards a little, look for rips or
tears (run your hand around the entire circle of the gasket, there could even
be a tear in the side or top, a little out of sight).
It's now
time to start taking the top off the machine (You have not supplied a make and
model, So I will guess that the top is held on by a couple of torque screws,
hidden behind a couple of plastic covers about the size of your little finger
nail on each side of the lid, or a couple of screws that are clearly visible on
the back of the lid, screwed through a plastic protuberance and into the
chassis - One of these two options will probably be correct!).
UNPLUG FROM
THE MAINS BEFORE YOU PROCEED!
Having
removed the 2 screws, you may need to give the front of the lid a sharp tap
backwards, to release the 2 plastic hooks in the lid from their holes in the
chassis, now the lid lifts off.
We are
looking for water, or marks where water has been (usually a little chalk
deposit unless you are in a very soft water area). Obviously, if one of the
following checks turns up something, you will have to replace the faulty
component.
Look around
generally. Pay particular attention to the pipes that lead from the water inlet
valves to the soap drawer, gently wiggle any rubber pipes looking for cracks or
loose connections. Look down the back of the machine. If the main bearing is
failing, then there may be rusty water splashes on the drum or inside the
chassis where water has come through the rusted bearing and splashed about as
the drum drive wheel has spun.
Still
nothing found? Go to the rear of the machine, depending on the make and model
there is a good chance that at the bottom you will find an oval-ish panel at
the bottom of the rear with a cutout for the empty pipe to exit through it,
held on by about 4 screws. There may be a larger and more substantial panel at
the back to remove, depending on the machine you have. Remove the panel.
You can now
see the motor, the empty pump and the lower half of the drum. Once again, look
for water, or water signs, particularly, look at the centre of the drum, if a
bearing has failed and water is leaking, there will probably be a rusty water
track visible from the centre of the drum, running down until it drips from the
bottom (Classically, the drips may have fallen onto the motor). If these signs
are there then I'm afraid the cost of repair is probably going to write off the
machine.
Check the
empty pump (The thing about 4 inches inside the body with the empty hose
attached). Look for signs of water.
If by now
you have still found nothing, you may feel competent and able to do the
following, BUT TAKE NO RISKS. You can plug the machine back in and set a
program running and watch what happens inside, look for water or sparks DO NOT
TOUCH OR APPROACH the machine in this condition. Have someone looking in the
back while you look in the top. Ensure that neither of you are close enough to
touch the machine while you do this.
I hope
that some of the advice works for you.
