Question about Danby DMW799 Microwave Oven
Hello, I have a Danby micrwave that is almost exactly a year old and it suddenly just stopped working. Seems to have no power at all, nothing works. Is there a simple fix or is it garbage already? Obviously not worth paying to fix as would probably be cheaper to replace (with a different kind next time!).
Posted by rlecce on
zappal
    Sergeant:
  • 256 Answers
If the display doesn't illuminate, replace the main fuse inside the unit.
Posted on Dec 24, 2017
1 Related Answer
Anonymous
SOURCE: My DANBY DMW744W 700 watts does not work?
What would cause the plastic turn table shaft plate holder in the center to ignite
Posted on Mar 06, 2008
I have a 2 year old ge micrwave. I shut the breaker off to change a furnace filter and now the microwave is not working and just says to "press clock". When I press the clock button, nothing...
If you press clock and nothing happens your keypad has shorted out and needs to be replaced. Try to unplug the unit one more time and try to turn the unit on again. If you have the same problem replace the control panel.
Dec 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Just stop working less than A YEAR OLD.
Seems to be a common problem for the looks of it. Mine was only a month old. Defect maybe?
Jun 08, 2010 | Danby DMW799 Microwave Oven
Microwace buttons suddenly stopped working. Only
Your membrane keypad is failing.
Contact Danby Customer Service US / Canada
If you;re not from the US or Canada, consult your owner's manual or the dealer you purchased it from to contact Danby to find find your nearest Danby servicer.
Jan 14, 2010 | Microwave Ovens
All works but no heat
Your magnetron tube may be defective.
--W/D--
Aug 12, 2009 | GE Microwave Ovens
My kenmore ELITE 721.64282 microwave/convection just stopped
I just had the exact same problem. :( Did you find anything out?
May 23, 2009 | Kenmore 63792 Microwave Oven
Danby DMW753W ; machine starts without any command
The membrane of the touch control is shorted and must be replaced.
Mar 27, 2017 | Danby DMW773 Microwave Oven
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
Feb 22, 2008 | Danby DMW650 700 Watts Microwave Oven
My microwave has stopped working and switched on suddenly!!
Sounds just like a bad door switch or door switch mount. Probably the upper one. Safety info, disassembly tips, and door switch test and replacement info are all available at our Web site. See http://tinyurl.com/yzjozk
Jan 14, 2007 | GE JVM1660 Microwave Oven
Danby DMW799 Microwave Oven Logo
113 people viewed this question
Top Danby Microwave Ovens Experts
gbob59
john h
acmservice
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
