Question about Hotpoint Ovens
Is this unit new?? Are you in the EU (EU regulations say appliances MUST be fitted with a plug) If it IS new, I would be talking to the supplier!
However, to address your question If it has a standard 3 core cable fitted, then it almost certainly should have a plug on it!
To reassure yourself, just use the simple formula of Watts divided by volts = amps
I'm presuming that you are in the UK (240 volt supply) and the oven is under 3KW (3000 watts)
This being the case 3000 watts divided by 240 volts = 12.5 amps, so you are OK with a 13 amp plug. Anything above a 3KW oven in the UK should have something meatier than a 13amp plug on it.
Of course, there is nothing to STOP you wiring it to a 45 amp outlet, but the fuse rating for the appliance should be matched to its maximum consumption to protect from faults failing to blow a fuse in a timely manner.
Posted on Jul 19, 2011
Jun 30, 2015 | Hotpoint Ovens
Jan 27, 2014 | Electrolux Ovens
Jan 11, 2014 | Hotpoint Ovens
Jan 28, 2011 | Hotpoint Ovens
Apr 07, 2010 | Ovens
Jan 20, 2010 | Ariston Technologies Ovens
Sep 10, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Sep 14, 2008 | AEG B5741-4 Electric Single Oven
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
276 people viewed this question
