This is a
common problem, often associated with a momentary power failure when the
controller doesn't get time to reset and return to an idle state before the
machine gets power back and it gets "confused". Regardless of the cause, you will almost
certainly find that unplugging from the mains (Not just powering off on the
button, as some door locks have a sneak circuit, even when the power is turned
off at the button) and leaving the machine undisturbed for a full 20 minutes
will allow a reset, the door lock will disengage and all will be well when you
power back up.
