Computers & Internet Logo
Posted on Jul 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to make a partition in windows xp - Computers & Internet
Anonymous
Level 3:
Guru:
  • Master 1,705 Answers
  • Posted on Jul 19, 2011
Anonymous
Master
Level 3:
Guru:
Answers
1705
Questions
Helped
402737
Points
5112
If XP is already installed, then you may have problems. Partitioning could wreck your operating system.
However if you do want to try, it is risky, here's a free program which should help:-
http://www.filehippo.com/download_easeus_partition_master_home/
However if you're re-installing XP, then its much easier. Just boot from your XP installation disk. Once files have transferred, it asks you where do you want to install windows.
This is where, 1 you delete all existing partitions first, then create new partition in the free space. You'll need to decide how to split your drive but I would suggest at least 25gb for Windows.
Once you've created your partitions, you can select the one you want to re-install windows on.
Bear in mind, re-installation removes all data from your PC, you'll need to back up any data you want to keep before you start.
1helpful
Dual boot xp with windows 8
No solution now, Install Windows XP again on first partition, Make sure BOOT.INI, NTLDR, NTDETECT.COM in the same partition in which Windows XP is loaded. Then install WIndows 8.
OR in the current scenario you've to do much technical work using third-party tools.
1helpful
INSTALLED ILLEGAL WINDOWS 7 AND WANT TO GET A LEGAL VERSION OF XP BACK
Hope this would be helpful. Kindly follow the instructions.
Prepare the hard disk according to the manufacturer's instructionsIf you are using a SATA hard disk, skip this step and go to the "Determine the type of file system that you want to use" section. If you are using an IDE hard disk, set the jumpers and the cabling according to the role of the hard disk (for example, master or subordinate) and make any required BIOS (or CMOS) changes. To set the jumpers and cabling, and make any required BIOS or CMOS changes, see the documentation that was included with your hard disk and motherboard, or contact the manufacturers.Determine the type of file system that you want to useYou can use either the NTFS or FAT file systems. NTFS is the preferred file system to format the hard disk unless you want to run an earlier version of Windows that cannot read NTFS partitions. For additional information about the differences between the FAT and NTFS file systems, click the following article numbers to view the articles in the Microsoft Knowledge Base: 100108 Overview of FAT, HPFS, and NTFS file systems 310525 Description of the FAT32 file system in Windows XP If the hard disk already contains data, back it upMake sure that you back up all your important data before you continue. When you partition and format a hard disk, all the data on that partition is permanently deleted. You can view current partition information without deleting your data. For additional information about how to use the backup utility or the Files and Settings Transfer Wizard, click the following article numbers to view the articles in the Microsoft Knowledge Base: 320820 How to use the Backup utility to back up files and folders in Windows XP Home Edition 309340 How to use Backup to restore files and folders on your computer in Windows XP 293118 How to use the Files and Settings Transfer Wizard 306186 How to use the Files and Settings Transfer Wizard from CD-ROM 306187 How to use the Files and Settings Transfer Wizard Disk in Windows XP If the hard disk has a drive overlay or a disk management program, make sure that it is compatibleIf your computer uses drive overlay software for large hard disk support, do not use the Windows XP Setup program to partition or to format the drive until you have verified that Windows XP is compatible with the software. If you have drive overlay software installed, contact the software manufacturer to find out whether it is compatible with Windows XP. If you are not sure whether you have drive overlay software installed, contact the manufacturer of your hard disk drive or motherboard.If you have software that you want to reinstall, verify that you have the disksMake sure that you have the original CDs or floppy disks so that you can reinstall the software programs after you partition and format your drive. If you purchased an upgrade for a program, make sure that you have the full version of the original program. Many upgrades for programs require a compliance check before you can install the upgraded product. If you cannot find the original CDs or floppy disks, contact the software manufacturer before you continue.If you have updated device drivers for peripheral devices, back them upIf you have installed an updated device driver for your peripheral devices (for example, modems and printers), make sure that you back up the new driver for the device to a location other than the drive that you want to format and partition so that you can reinstall it after you install your operating system.Configure your computer to start from the CD or DVD drive To start your computer from the Windows XP CD, your computer must be configured to start from the CD or DVD drive. In some cases, you may have to modify your computer's BIOS settings to set this configuration. For information about how to configure your computer to start from the CD or DVD drive, see the documentation that is included with your computer, or contact the computer manufacturer.
If you have a computer that cannot start from the CD or DVD drive and you need to start your computer from the startup disk, make sure that you have the floppy setup disks so that you can run the Setup program from the floppy disk drive.
Note You can obtain Windows XP Setup boot disks from Microsoft, but only by download. We provide the Setup boot disks so that you can run the Setup program on computers that cannot use a bootable CD-ROM. If you can start your computer from a CD-ROM or from a network-based installation, we strongly recommend that you use those installation methods instead. Future products will no longer support installation by using the Setup boot disks.uparrow.gifBack to the topHow to partition and format the hard disk using the Windows XP Setup programYou can use the Windows XP Setup program to partition and format the hard disk. To do this, use the following steps:Step 1: Partition the hard disk
  1. Insert the Windows XP CD into your CD or DVD drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer to start the Windows XP Setup program.
    Note If you are using the Windows XP Setup disks, insert each additional disk when you are prompted, and then press ENTER to continue after you insert each disk.
  2. If you are prompted, select any options that are required to start the computer from the CD or DVD drive.
  3. If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver. For more information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base: 314859 Limited OEM driver support is available with F6 during Windows XP Setup
  4. At the Welcome to Setup page, press ENTER.
    Note If you are using the Setup disks (six bootable disks), the setup prompts you to insert the Windows XP CD.
  5. Press F8 to accept the Windows XP Licensing Agreement.
  6. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  7. All existing partitions and non-partitioned spaces are listed for each physical hard disk. Use the ARROW keys to select an existing partition, or create a new partition by selecting the non-partitioned space where you want to create a new partition. You can also press C to create a new partition using non-partitioned space.
    Note If you want to create a partition where one or more partitions already exist, you must first delete the existing partition or partitions, and then create the new partition. You can press D to delete an existing partition, and then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each existing partition that you want to include in the new partition. When all the partitions are deleted, select the remaining non-partitioned space, and then press C to create the new partition.
  8. To create the partition with the maximum size, press ENTER. To specify the partition size, type the size in megabytes (MB) for the new partition, and then press ENTER.
  9. If you want to create additional partitions, repeat steps g. and h.
  10. To format the partition and install Windows XP, go to step 2.
    If you do not want to install Windows XP, press F3 two times to exit the Windows Setup program, and then do not follow the remaining steps in this article.
    To format the partition without installing Windows XP, use a different utility.
Step 2: Format the hard disk and install Windows XP
  1. Use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER.
  2. Select the format option that you want to use to format the partition. You can select from the following options:
    • Format the partition by using the NTFS file system (Quick)
    • Format the partition by using the FAT file system (Quick)
    • Leave the current file system intact (no changes)
    Notes
    • If the selected partition is a new partition, the option to leave the current file system intact is not available.
    • If the selected partition is larger than 32 gigabytes (GB), the FAT file system option is not available.
    • If the selected partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm).
    • If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
    • If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you are prompted to select a file system for both the System and Startup partitions.
  3. Press ENTER.
  4. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to install Windows XP. After the Windows Setup program is finished and you have restarted the computer, you can use the Disk Management tools in Windows XP to create or format more partitions. For additional information about how to use the Windows XP Disk Management tools to partition and format your hard disk, click the following article number to view the article in the Microsoft Knowledge Base: 309000 How to use Disk Management to configure basic disks in Windows XP
uparrow.gifBack to the topAdditional notesBefore you can install an operating system such as Windows XP, you must first create a primary partition on the first physical hard disk (Disk 0) on your computer. Then, you can format a file system on that partition to create what is called the System partition.
Or, you can create a separate partition for the operating system on any physical hard disk. This is known as the Startup partition. The System partition on Disk 0 can also be used as a Startup partition.
7helpful
How to reformat window xp
Reformat the Hard Drive in Windows XP
  1. To reformat a hard drive with Windows XP, insert Windows CD and restart your computer.
  2. Your computer should automatically boot from the CD to the Windows Setup Main Menu.(If not, press F2 or DEL and choose first boot device CD or DVD)
  3. At the Welcome to Setup page, press ENTER.
  4. Press F8 to accept the Windows XP Licensing Agreement.
  5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  6. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.
  7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
  8. Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.
  9. You have now sucessfully reformatted the hard drive with Windows XP.
Format
How to partition and format the hard disk using the Windows XP Setup program loadTOCNode(2, 'moreinformation'); You can use the Windows XP Setup program to partition and format the hard disk. To do this, use the following steps: Step 1: Partition the hard disk loadTOCNode(3, 'moreinformation');
  3. If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver. For more information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base: 314859 (http://support.microsoft.com/kb/314859/ ) Limited OEM driver support is available with F6 during Windows XP Setup
Step 2: Format the hard disk and install Windows XP loadTOCNode(3, 'moreinformation');
    Notes
  3. Press ENTER.
  4. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to install Windows XP. After the Windows Setup program is finished and you have restarted the computer, you can use the Disk Management tools in Windows XP to create or format more partitions. For additional information about how to use the Windows XP Disk Management tools to partition and format your hard disk, click the following article number to view the article in the Microsoft Knowledge Base: 309000 (http://support.microsoft.com/kb/309000/ ) How to use Disk Management to configure basic disks in Windows XP
Tanks. Cheer!
2answers
Gateway MX6455 - AMD Turion 2.0Gb with 1Gb Ram Stops working and goes to black screen after POST. Will not boot into windows. The more I try re-booting, the faster it stops.
If you recently installed and any new program it could be a corrupt driver. Boot to safe mode by hitting F8 and delete it. If you didn't, you will have to remove drivers individually. Failing hardrive is another culprit.
2answers
How do i remove windows vista and install windows xp with out losing all my other stuff
If your Vista still work, go to the control panel> administrative tools> computer management > disk management > create an additional partition (larger then my documents folde size)
Move your files to this partition then install xp.
A few tips
  • Make sure there xp drivers for each componenet
  • Use driver magician and find xp drivers (check the pc mfg site and download all xp drivers and put them on this partiton too.
  • Use a partition program (dos) and format the vista partition and the hidden partition that vista creates or xp won't go in properly
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
I have 40gb hdd.need a partition scheme for windows xp such that i have 17GB gb for my games THANK YOU
Using the Windows XP installation disk, procede to install windows normally. In the windows setup you will get a list of options. Choose "C" to create partition. Create a 20GB partition. When that is done create another 20GB partition unless you plan on installing another Operating System such as Windows 7 later. If you want to keep XP and install Windows 7 at a later date on the same PC, then Set up 2 - 10GB partitions for Operating Systems and 1 - 20GB partitions for games. Make sure to install the games on the 20GB drive letter only so that Windows has enough space to run.
2answers
How to install xp in HP Pavilion dv6 1030 us Laptop and how to repartition my C: drive especially I have still 150 GB free space in C drive Please help me in this case Thanks in advance.
get a winxp installer CD, you can repartition your drive on the first part of the winxp installation process. Prepare your drivers for your machine especially the network and USB drivers which you will need to copy and transfer files firstly.
If u meant of installing an additional OS like winxp to your extra space, you need a boot loader to switch between OSes.hope this helps
HDD Partition help
Important If you follow these steps on a hard disk that is not empty, all the data on that hard disk is permanently deleted. We recommend that you back up your hard disk before you follow these steps.
To partition and format your hard disk by using the Windows XP Setup program:
1. Insert the Windows XP CD-ROM into your CD-ROM drive or DVD-ROM drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer.
Note To start your computer from the Windows XP CD-ROM (or from the startup disk), your computer must be configured to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive. In some cases, you may have to modify your computer's BIOS settings to set this configuration. For information about how to configure your computer to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive, see the documentation that is included with your computer, or contact the computer manufacturer.
2. If you are starting the computer from the Windows XP CD-ROM, select any options that are required to start the computer from the CD-ROM drive if you are prompted to do this.
Note If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver.
For additional information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base:
314859 Limited OEM driver support is available with F6 during Windows XP Setup If you are starting from the Windows XP Setup disks, insert each of the additional disks when you are prompted, and then press ENTER to continue after you insert each disk.
6. All the existing partitions and the unpartitioned spaces are listed for each physical hard disk. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition by using unpartitioned space. If you press D to delete an existing partition, you must then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each of the existing partitions that you want to use for the new partition. When all the partitions are deleted, select the remaining unpartitioned space, and then press C to create the new partition.
8. Repeat Steps 4 and 5 to create additional partitions if you want them.
9. If you want to install Windows XP, use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER. If you do not want to format the partition and install Windows XP, press F3 two times to quit the Windows Setup program, and then do not follow the remaining steps. In this case, you must use a different utility to format the partition.
10. Select the format option that you want to use for the partition, and then press ENTER. You have the following options:
The option to leave the current file system intact is not available if the selected partition is a new partition. The FAT file system option is not available if the selected partition is more than 32 gigabytes (GB). If the partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm). If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
Note If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you will be prompted to select a file system for both the System and startup partitions. 11. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue. After the Windows Setup program is completed, you can use the Disk Management tools in Windows XP to create or format more partitions.
Grand Canyon Tech
Grand Canyon Tech
