My washer was making a squealing noise and I thought it was the water fill valve. A new valve is about $100, so I decided to do some more research. Turns out that the pump needed to be lubricated. Only took 10 minutes and a couple of shots of white lithium spray grease on the pump bushings.
Possible there is dirt in the drain which seems to clog on the drain pump /valve and so when the drain cycle is activated the pressure makes the noise on the pump.
Check for tips to remove the Pump;
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
