DearFriend (shabsohel999),
I saw 2 queries from youon Lava A10:
1) Your original Javasettings on Lava A10 is messed up and you need the settings again. Pls. find below the Java settings on A10:
Javaaudio: (Default is 4). You can select thelevel you want
Javavibration: (Default is ON). You can selectthe vibration "On" or "Off"
SelectSIM: (Default is SIM1). You can selectSIM1 or SIM2, depending on the SIM you want to use to launch the Javaapplication.
JavaSIM1 profile: Select your operator from thedrop down list.
JavaSIM2 profile: Select your operator from thedrop down list.
2) You want to know theway to do GPRS Settings.
- Ideally, as soon asyou insert any SIM card in the Lava A10 handset you should get the GPRSsettings from your operator in the form of an SMS. You can click on"Install" and the settings will be done automatically.
- But in case you do notget the settings automatically, you can call your operator and they will provideyou the necessary settings. The GPRS settings are operator specific. Lava A10is already registered with all the major operators in India, so will get the GPRSsettings without any problem.
- In case your problemis not solved by the above mentioned ways, than pls. let me know your Operatorname and your city. I will directly send you the GPRS settings directly.
You can reach me directlyon [email protected]for any futher help.
