If it is a SD or SDHC memory card, there is a small write protect switch on the side of the card. Remove the memory card from the camera and slide the switch to the unlocked position.
What type and size memory card? The A430 works with SD cards. It won't work with SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
When this problem occur you need to set the memory card unlock or not
protected.
Remove the memory card from camera and you can see a small button in
the memory card, so you need to slide that to set the memory card unlock
or not
protected.
protected.
or not
protected.
It is not the camera it self you need to unlock but it is the SD memory card.To unlock a SD memory card switch off the camera
and remove the card. You will find a slide switch on the side of the
card that needs to be slid to unlock the card..
When this problem occur you need to set the memory card unlock or not protected.
the memory card, so you need to slide that to set the memory card unlock or not
protected.
if we are talking about an SD card ...see that in a side ..the card has a slide like button with 2 positions ...locked and unlocked... just unlock it cause it might have been locked when handling it...
- Turn off camera
- Remove memory card
- Take a look on the switch of the memory card itself
* If it's at the TOP = card is UNLOCKED
* If it's at the BOTTOM = card is LOCKED
- So, you just have to make sure that the switch is at the top
for the memory card to be UNLOCKED
After doing that, you just have to put back the memory card to your camera and turn on the camera. Try to check if this works.
