Question about Zynga FrontierVille
I am having problem with my frontiervillle apps freezing up
Posted by koehler_ruth on
Joseph Hoffmann
    President:
  • 1,755 Answers
Hi, You need to free up some space on your computer's HDD. Also delete your internet files. (cookies).
If this freezing keeps up you may need more memory space.
Posted on Jul 19, 2011
Iphone 5c freezeing up when I try to delete apps
iPhone or iPad freezing when you delete apps Here the work around
1)Double tap home button on iPhone or iPad to bring up multitasking mode
    2)Swipe all open apps up in order to close up
    3)You can touch and throw away up to three apps at once to save time
    Once all aps have been closed, try deleted the app again
Oct 26, 2015 | iPhone Apps
My android 4.4 kitkat tablet freezes when apps are updating.Is there aything I can do?
In your settings for the google app store you can change it to require you to authorize any app being updated. that way you can skip the ones you don't care about, or all of them, to avoid them problem.
Nov 04, 2014 | Tablets & eReaders
Phone keeps freezing
> Check the number of applications that are running in the back ground close some and check if it still freezes
> Try to identify from when the phone started freezing - if there was an app you downloaded prior to that uninstall that app and check if still freezes
> you can also install an anti virus and run a scan to check if your phone is infected
Oct 23, 2013 | Vodafone Cell Phones
Phone freeze
To get Samsung s8000 jet freeze code visit Unlock-zone.com .Here specify your country,network provider then you can get freeze code.
Apr 28, 2013 | Samsung Jet S8000
Mobile " phone freeze "
Hi, it should be possible to solve Phone freeze on Fastgsm.com. Just select your phone model, I hope it's supported.
Apr 21, 2013 | Cell Phones
Phone says phone freeze sim unavailable when I
If the Phone says Freeze Sim unavailable means you need to Unfreeze it,You can get the unfreeze code from here Classicunlocking.com and Unfreeze it...
Aug 06, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
My huawei ascend keeps freezing up to the point i need to take out the battery, when turned back on, it works fine for about one minute before freezing up, i have deleted all apps and run an avg virus...
you may have too many apps. you only have megabytes of space on your internal sd card memory and I had to remove most of my apps and then my phone went back to almost normal. the fb for android and twitter app, and also tweetdeck freeze up your phone really bad so I am now using tweetcaster and using fb only to get my msg notifications. I am using dolphin browser and bookmarking fb to use instead, which works really well. no chat though. I know this because I just spent 2 hours fixing my phone, removing apps, trying things out. hope that helps you.
Feb 06, 2011 | Cell Phones
Phone freezes whenever I press "End" key or the "Clear" button
Hey,
Thanks for nothing people. I figured it out myself. It turns out I had a miniSD card I had been using with my laptop in the phone and it was formatted in a different format that the phone didn't recognize (I use Linux on my laptop, and Linux uses different file formats then Windows). The different format must have caused the phone to freeze, because after I took the miniSD card out, the phone went back to working properly (unless smacking it on the table whenever it would freeze helped. lol jk jk). I hope this helps someone else who has trouble with a freezing eNV.
Adios Beeches,
-OP13
Jun 18, 2009 | LG enV VX9900 Cellular Phone
PLEASEE DONT FREEZE
the card maybe corrupted so try a new memory card. and see if that helps if it still freezes then have the phone exchanged.
Mar 31, 2008 | LG Shine KE970 Cellular Phone
Zynga FrontierVille Logo
73 people viewed this question
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Vincent G
Vincent G
Andrew Taylor
Andrew Taylor
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
