Question about GE PFS22SISSS Stainless Steel French Door Refrigerator
Hi,my ge pfs22sisss need door aligment. How do i adjust doors. Thank you
3 Suggested Answers
Master_Tech
Gary Davd
  • 770 Answers
SOURCE: leveling old refrigerator
you can adjust the front rollers by turning the screws at the bottom behind the toe kick
Posted on Jun 09, 2008
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: My GE ice maker has forzen up with too much ice & wont eject
Unplug refrigerator, remove frozen food and use a hair dryer on the ice to remove it. Thanks, Sea Breeze
Posted on Mar 24, 2009
Anonymous
  • 21 Answers
SOURCE: Door Adjustment - Is it possible?
IF DOOR IS NOT SHUTTING WELL REPLACE BOTTOM HINGE AND CAM COMES AS KIT
Posted on Jul 15, 2009
How to dispense water through door
if you hear a buzing sound when pushing the water dispenser, replace the water valve and be sure to defrost the fill tube at the ice maker. if no sound, you need to check for power at the water valve while pressing the dispenser. if power present, replace valve. no power, check the switch behind the dispenser arm.
Jan 05, 2014 | GE PFS22SISSS Stainless Steel French Door...
Pfs22sisss the temperature control displays quit working. unplug unit from the wall, plug back in and the displays work for a while then go out. also the condenser fan isn't running. when the compressor is...
Hello Rogerspray,
I understand that you are having a problem with your GE refrigerator the fan is not working and the power board is not working. The fan should always run when the compressor is on and sometimes when the compressor is off as it is to circulate the air.
You will need to replace the fan this can be removed and taken to any local hardware store and purchased as the are not expensive.
It sounds like you also need to replace your power board. I have located you one on Sears Parts DIrect it costs $91.33 and can be located at this link power board.
In-order to replace both of these items you will need to:
1. Turn off power
2. Remove cover panel
3. Disconnect quick connects
4. Remove item
5. Install new item
6. Replace wire to same terminals
7. Replace cover
8. Turn on unit and check
Replacing these items should take care of the problem that you are experiencing.
Thank you for choosing FixYa.com
Justinbur167
Apr 25, 2011 | GE PFS22SISSS Stainless Steel French Door...
PFS22SISBSS CLICKING AND NOT COOLING
Hi this is the main control board, part # WR55X10942, this should fix your problem.
Thanks for using fixya.com, if this has helped please rate my answer. Thanks!
Mar 30, 2011 | GE PFS22SISSS Stainless Steel French Door...
My ge tfx28pb has water frozen at the bottom of the freezer, what is wrong
the drain is pluged with ice and causing the water to run onto the floor of freezer .. defrost drain with hot water and a turkey baster . this shoould solve problem .. mm
Aug 10, 2010 | GE PFS22SISSS Stainless Steel French Door...
Regarding GE french door model pfs221sbss, need
I would call your GE service company and give them the model number and serial number of your frig. They can look up which board fits your frig.
I hope this helps.
Feb 03, 2010 | GE PFS22SISSS Stainless Steel French Door...
My frenchdoor fridge keeps running constantly. Doors are fully closed and the temp seems right (now!!) but the motor keeps going. what can I check? Please & Thank you!
does it run all night too?
the fridge will run as long as it needs to to obtain and maintain the selected temperature,
the freezer should be set to zero and the fridge to 38
Sep 04, 2009 | GE PFS22SISSS Stainless Steel French Door...
Some strawberry ice cream melted and re-froze in the bottom of my freezer. How do I get it out
Warm to hot water and a rag. Very simple get a pale to keep water rung out from wrag.
Aug 07, 2009 | GE PFS22SISSS Stainless Steel French Door...
Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Jul 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
What lubricant inside a refrigerator?
spray silicone.some are flamable,but just give a little spray and let the solvent evaporate,just takes a minute.i have done this many many times on service calls.i buy the walmart brand. God bless ,tom
Jan 24, 2009 | GE PFS22SISSS Stainless Steel French Door...
Want to turn off ice maker
To reach the icemaker power switch, pull the
shelf above the ice bin straight out. Always
be sure to replace the shelf.
Jan 13, 2009 | GE PFS22SISSS Stainless Steel French Door...
GE PFS22SISSS Stainless Steel French Door Refrigerator Logo
29 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
Vish Iyer
Vish Iyer
