DOUBLE CHECK YOUR RCA CABLES. MAKE SURE THEY R GOOD & THAT THIER IN THE RIGHT SPOT ON THE AMP AND RADIO DECK.IF YOUR LIGHTS COME ON. THEN TRY THIS........ IF THAT DOES NOT WORK. CHECK TO SEE IF YOUR SUBS R CONN IN THE SUB BOX.IT COULD B SOMETHING THAT SMALL
The red light usually means "protection" and that there is a problem. Low voltage etc... Check the main lead and check the voltage on the trigger wire and the fuse on the amp.
Check the fuse in the amp. There should also be a fusable link that houses a huge fuse, if that blows it will give the same effect. You will want to check to make sure that the wire that runs from your battery to the amp is secure and free of corrosion as well. If all of the above is fine, then I would recommend that you check to see if the rca cables are plugged in securely in the head unit.
OK ! FIRST THINGS FIRST. DID U TEST THE AMP FIST. BEFORE U STARTED INSTALLING RCA CABLES,AND REMOTE WIRES. LETS DO THAT FIRST.GRAB YOUR AMP.SET IT ON YOU WORK BENCH ,TABLE,OR CHAIR.THEN GET (2)PIEACES OF #10 OR #12 WIRE W/1 OF THE WIRES HAVING A 20AMP FUSEABLE LINK ON IT.NOW THE WIRE W/THE FUSEABLE LINK ON IT.CONN THE REMOTE(REM) AND THE 12v + ON THE AMP AND HOOK THEM BOTH TOGETHER ON 1 SIDE OF THAT FUSEABLE LINK WIRE. AND THE OTHER WIRE HOOK IT UP THE - GROUND SIDE OF THE AMP .NOW PICK UP YOUR AMP OPEN UP YOUR HOOD.MAKING SURE THAT NO WIRES OR THE AMP IS TOUCHING THE + 12V OF THE BATTERY. NOW CONN YOUR GROUND TO GROUND AND THE FUSEABLE LINK ON THE +12v SIDE OF THE BATTERY.NOW THE AMP SHOULD HAVE CAME ON. LOOK 4 A SOLID RED LIGHT OR ANY SIGNS OF A SOLID LIGHT THAT HAD CAME ON.
All amps are basicly the same. It should be plain as day where the speakers connect to. The 12V screw connects to the main power from battery, be sure to fuse that wire and use a proper size wire, thicker is better,I suggest at least 8gauge with 40amp fuse. The GND is ground and should connect to car metal, file paint for soild connection. The REM is remote and connects to the remote of headunit or if you have a stock deck to the acc of car found in wire harness of headunit. Plug in the RCA's to head unit, or get a converter to plug into speaker wires from car if you have a stock headunit.
that means you probably have a shorted speaker wire, a bad speaker or the amp itself is bad, try disconnecting the speakers one at a time and see if it turns on or not. if the red light stays on with no speakers hooked up it means the amp is bad
Your KAC-5204 amp is only rated to put out 60 watts per channel and really cannot push very hard. If your subs are the KFC-W110S, they are 8ohm subs and you will get better power from the amp by using the bridged connections, positive (+) on the left channel and negative (-) on the right channel. Wire both positives and both negatives from both subs to the bridged connections and the output will be 150 watts into 4ohms. Giving each sub 75 watts should make them push a little harder.
