It may be in defrost mode. Look at the temp control on the underside for a hole with no
screw in it that appears to serve no purpose. Using a flathead screwdriver, turn the
mechanism inside the hole, (it is the defrost timer) and see if the unit comes on. If no
luck, then replace the start relay which is located under the plastic cover on the side of
the compressor. It plugs onto the compressor on three pins, if no replacement is available
they make a "universal" start kit for about 8 dollars which plugs onto these pins and has
good instructions. Model and serial number are usually inside the fresh food compartment
on the left side. The appliance parts store should have this item readily available.
Hope this helps :) remember to unplug unit before replacing any parts.
