Question about Whirlpool Duet Sport HT WFW8400TE Washer
Hi, F-28 means SERIAL COMMUNICATION ERROR
The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes/Procedure
Unplug washer or disconnect power,check wire harness connections to the MCU, the motor, and Central Control Unit (CCU). Check connections of the CCU board within the housing.
Make sure all grounding switches are engaged.
Check the drive system for any worn or failed components.
Plug in washer or reconnect power.
Verify CCU operation by running a Diagnostic Test or any cycle.
Check the MCU by looking for operations of the drive motor.
Check the drive motor for powered rotations.
Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors. there is usually a service diagnostic tech sheet in the bottom front of the cabinet behind the panel under the door.
Posted on Jul 18, 2011
Nov 03, 2016 | Maytag Washing Machines
Mar 29, 2016 | Washing Machines
Jan 12, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Apr 19, 2013 | Computers & Internet
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Jun 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Jul 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Nov 23, 2017 | Whirlpool Duet Sport HT WFW8400TE Washer
88 people viewed this question
