OK...but if the sides are bulging all around will the water even itself out as it fills to the proper spec diameter of the floor of the pool..cuz right now its bulging past the diameter of pool floor...will it even outOK...but if the sides are bulging all around will the water even itself out as it fills to the proper spec diameter of the floor of the pool..cuz right now its bulging past the diameter of pool floor...will it even out
You can't post conmments that contain an email address.
They run true to size for length. There are icons on the sole that tell you the width. A filled in icon is medium width snd an outlined foot shows narrow and wide.
They make what is basically a very short extension cord with a gfci at one end. Plug you motor cord into the receptacle end. If the motor cord end needs to be replaced, put a new plug on it.
Watch the polarity. The white wire goes on the wide prong, the (usually) black wire goes on the narrower prong and the green wire goes on the bottom prong.
YOU MIGHT HAVE SET THE VOLTAGE WRONG.. IS THE MAIN BREAKER WIDE OR NARROW ? IF THE BREAKER THAT RUNS THIS PUMP MOTOR IS NARROW YOU NEED TO SET THE MOTOR FOR LOW VOLTAGE 115V ON THE MOTOR LABEL THERE IS A DIAGRAM ON HOW TO SET IT.. YOU NEED TO GIVE MORE INFO LIKE PUMP MANUFACTURE, TYPE AND MOTOR SIZE HP AND SF SERVICE FACTOR..WELCOME TO MY WORLD ! .JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXYA GUY
You're trying for what's called a narrow depth of field. DoF is controlled by three factors: distance from camera to subject, lens focal length, and lens aperture. The closer the camera is to the subject, the narrower the DoF. The longer the lens focal length, the narrower the DoF. The larger the lens aperture, the narrower the DoF.
Get as close to the subject as practical, and use as long a focal length as practical. I realize these two aims conflict with each other. For portraits, you want a focal length in the 50-90mm range and move in to fill the frame.
You want to shoot with as wide an aperture as you can. Unfortunately most lenses are not at their sharpest wide open. Also, the 18-55mm lens doesn't open up all that wide, f/3.5 at 18mm and f/5.6 at 55mm. To get the widest aperture, you can shoot in the P or A modes. If you don't want to leave the point&shoot modes, try using the Portrait mode.
Since you're not paying for film, I suggest you experiment with the different settings and shooting setups, moving closer and farther from the subject, using different focal lengths, and using different apertures, and see what results you get.
Width is the measurement across the widest part of your forefoot.This measurement runs in correlation to the length of your foot, and can best be found by having you foot properly measured. The average men's width, typically referred to as medium, is a men's D width. For women, the average, or medium, is a B. Listed below is a chart that helps indicate the width markings and their meanings. Women's Widths . 4A -Extra 2A-Narrow B- Medium D-Wide 2E-Extra Wide 4E-Extra Extra Wide. Men's Widths - 2A -Extra Narrow. B-Narrow. D- Medium.2E-Wide. 4E -Extra Wide.6E- Extra Extra Wide.
