I want to know how to swich the tv to wach dvd player? the remote works with the tv but how can i swich to wach a movie....i dont want to set up the remote to the dvd...
    Scholar:
  • 81 Answers
Sounds like you need to change the input channel of your TV with your TV remote. Look for an Input or Video Source button. Once you've found it, insert a DVD then cycle through the inputs with that button until you see something on the screen. As always this could be undermined by incorrect connections to and from and the DVD player. Double check these as always!
Posted on Jul 18, 2011
    New Friend:
Using remote control or button on front of tv to change channels, change to channel 999. found this digging around on internet for same problem. assuming you have hooked up dvd player to tv, of course
Posted on Feb 29, 2012
6ya staff
SOURCE:
Lost remote control of my lg dp122 and now i dont know if i can play movies
get a logitect universal remote and set it up to the dvd player.
I know what you are asking and I don't think you will be able to move or select sub menus on movies without a remote.
or buy another remote
http://www.ebay.com.au/itm/like/261378869015?hlpht=true&ops=true&viphx=1&lpid=94
Jan 26, 2014 | LG DP122 DVD Player, Multi Format...
The movie that we are trying to play just keeps loading... we've tried multiple things for over an hour and it still doesn't work...
Try this. Get the TV remote, not the DVD remote but the remote for your TV. Bring up the menu and there should be an option for source. Our TV requires the TV source to be set to TV for the DVD player. After the movie is finished, remember to set the source back to where you had it. Hope this helps.
Mar 28, 2010 | Sony BDP-S350 Blu-Ray Player
How do I watch a dvd movie on tv? I have the dvd
press the av or au bullon on remote until you get to the dvd "channel"
Feb 11, 2010 | GE 19GT243 19" TV
Cannot get the visual from the videos
Today with HD High Definition TV these kind of problems appears because the new dvd players have more video resolution options, so, for playing all variety of dvd, and home done dvs,s (like family movies on dvd) you need set up your resolution video on your DVD player at 480i or 480p option, not higher because some DVD movies (mainly oldies) have lower resolution than newer , for example new movies on HD format have 1080 P resolution, and if you have this option chosen in your DVD player you only can see this kind of videos, on the other hand if you have chosen 480i or 480 p on your dvd player , you can play all dvd formats including home movies made with any movie software, in this way you can play dvd-r and +r movies and of cours you can play HD movies also. So put some dvd where your dvd player works well (you need see the dvd menu in the tv screen), then press stop. Then press setup in your remote control, go to video resolution and choose 480 I or 480p, then press ok AND ENJOY THE MOVIE.
Smart techniques
Jun 24, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Programming dvd player
It sounds like you may not be on the correct input selection on the tv to watch the dvd player. Ther are probably three or four inputs to choose from on your tv. whichever input you hooked the dvd player into on the tv is the same imput you have select using the tv's remote control in order to watch movies on the dvd player.
May 31, 2009 | iLO 3200 32 in. LCD Television
How do I get to the ''Menu screen'' when playing a DVD movie?
It's likely the remote has the wrong code, so it will only work certain functions. You need to try lots of codes, if you do not know the player's code, till ALL function buttons work, not just some.
Aug 09, 2017 | Logitech Harmony 670 LCD Remote Control
Swiching from tv to playing video
sorry. you cannot switch to video mode without the remotes
Feb 21, 2008 | Disney Princess MCP DVD2050P DVD Player
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
I dont have a remote ! how do i set the TV to the dvd player?
there should be a set of controls on the front of the tv that you can change the channels and settings from there
Dec 13, 2007 | JVC AV-36320 36" TV
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
