Question about Garmin StreetPilot 2620 GPS Receiver
My garmin will not load maps and cycles like it is trying to turn on. Is there a way to reset the device or is it toast?
Posted by quackquac80 on
5 Related Answers
Anonymous
  • 2920 Answers
SOURCE: Garmin Nuvi 360 Won't Load Maps
go buy a tom tom you dont havve to do any downloads to keep it up to date.garmin has to many issues
Posted on Aug 25, 2008
jonniewalker
Starnley Johnwells
  • 1031 Answers
SOURCE: how to load maps from google to garmin
This solution works for more than the 760. i think it will work for all 6xx and 7xx series.
a simple solution to convert Google maps to Garmin routes and is found here:
http://www.elsewhere.org/journal/gmaptogpx/
In essence, you create your route in Google maps and then click the recommended url bookmark.
Save the GPX file to the Garmin device and from "My Data" (under Tools) convert the file to a route. You are done.
hope this helps pls appreciate by rating as fixyaa thanks
Posted on Nov 23, 2008
Anonymous
SOURCE: Garmin Nuvi 205 keeps saying no maps available ???
First you will want to empty your recycling bin & clear your temporary internet files before re-downloading the Garmin_RMU_2010B.exe file.
Below is the remainder of the fix I received from Garmin support and it worked for my unit. Hope this helps.
1. Extract the downloaded file Garmin_RMU_2010B.exe using 7zip(7zip.org) or WINRAR.
http://downloads.sourceforge.net/sevenzip/7z465.exe 32 bit
or
http://downloads.sourceforge.net/sevenzip/7z465-x64.msi 64 bit
2. After extracting, the files should be available at the location where you extracted the files.
3. Go to the extracted file location. Click on the Windows folder.
4. Right click on the Setup.exe file and Click Create Shortcut
5. Right click on the Shortcut to Setup.exe file and Click Properties
6. In the target line add " -build_map_image 006-D0783-04 " at the end of setup.exe". For example the end would look like xxx\Setup.exe" -build_map_image 006-D0783-04
7. Click Apply and OK.
8. Double click on the Shortcut to Setup.exe the map file will be built. Leave the Window open till completion of all steps. 9a. Windows XP: Click on Start>Run, then type in %Temp%. Another window will open.
9b. Windows Vista: Click on the Start Button, in the Start Search, type %temp%. Another window will open.
10. The file is placed in subfolder named 006-D0783-04.
11. Copy the gmapprom.img file from the folder to the Garmin folder on the Nuvi. (Double click on MyComputer>Nuvi drive>Garmin folder) Overwrite the existing file.
12. The Nuvi should now have the lower 49 installed. If you have any trouble with this fix, or are not comfortable trying it please call our Software Support Department at 1-800-800-1020. Please be at a computer that has high speed internet access as we may need to log on to your computer to resolve the issue. Make sure you have the program extracted using the 7 zip program provided above. Hours of Operation Monday – Friday: 8 am – 7 pm Central time (closed holidays)
With Best Regards,
Joyce K
Software Support Specialist
Software Team
Garmin International
913-397-8200
800-800-1020
913-440-8280 (fax) Att: Joyce K
www.garmin.com
Posted on Apr 28, 2009
Anonymous
  • 50 Answers
SOURCE: My Garmin shuts off in the loading maps screen
first I would try to load the current firmware from garmins website. if that doesnt work then try a master reset by holding the bottom right corner of the screen, holding that and turning it on. it will however erase all user data.
Posted on Aug 15, 2009
Anonymous
  • 2335 Answers
SOURCE: hi my garmin nuvi 205w has gone into some kind of
Try the Hard Reset procedure outlined in this tip.
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them.
A hard reset (or Clear All User Data)has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will beread from 'temp.gpx' into the non-user accessible memory area on theNuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
Ifpossible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
Posted on Jan 15, 2010
My Garmin Nuvi 265W will turn on but not load. I have tried holding the right hand corner etc. Any suggestion
Do a hard reset on the device. Download Garmin Express and install it to your PC. Connect your device to your PC. Garmin Express will identify it and allow you to install all the maps and software that the device has a subscription to.
Apr 29, 2017 | Garmin GPS
Garmin 265w i turn it on and it stays on the screen that says loading maps did the 15 sec reset same HELP!!
you have same maps on sd card and on garmin internal memory and garmin became confused when you turn it on
Dec 16, 2010 | Garmin nuvi 265 Car GPS Receiver
My garmin turns on but freezes when loading maps. I tryed to reset but did nothing.sometimes it will stay froze and sometimes it will turn itself off.serial #12p238176
Clear all ur installed apps/data/music/pictures first. Turn the unit off and then on. while on, reset it again. turn it on again and now connect it ur PC to load additional maps and see if it helps.
thanks
Aug 11, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 255w won't start up. tries loading maps and then goes in a continuous circle. acts if not charging. tried reseting and charging with wall charger and car charger
You should try to manually delete the maps (after a backup ) on the device , power cycle and retry sending the maps from MapSource or the Software CD from the manufacturer. The map is a single folder onto the device (eg. gmapsupp.img)
May 25, 2010 | Garmin nuvi 255W GPS Receiver
My Garmin shuts off in the loading maps screen every time we try to turn it on. It will flash the Garmin logo when it gets turned on, go to the loading maps stage and then just shut off. Any ideas?
Aug 12, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 250
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Jul 14, 2009 | Garmin nuvi 250W GPS Receiver
My Garmin 780 will not turn on
Hi, Try to reset by holding the 'On' button. After the reset if the Map is not loading in the background then it may be corrupted. If you can connect the GPS to the computer then you can call the Garmin support and get the MAPS which you can eventually load. If the GPS is not getting connected to computer then you need to send it to Garmin to fix it. Hope it is under warranty.
Samething happened to me. Garmin service is wonderful, they replaced it..
VM
Dec 27, 2008 | Garmin nuvi 780 GPS
After trying to install new maps, Garmin nuvi 350 don't start
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 30, 2008 | Garmin nuvi 350 GPS Receiver
Garmin StreetPilot 2620 GPS Receiver Logo
Top Garmin GPS Experts
Sheldon Dedek
Tom Chichester
Bill Boyd
Are you a Garmin GPS Expert? Answer questions, earn points and help others
