Question about Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers
I have a Sony S Wireless Audio Transmitter AIR-PC10T with the Sony Wireless Audio Remote RM-ANU062 It transmits to a Sony 2-channel audio receiver STRDH100 Two days ago the signal stared cutting out on me both on live streaming and Blue Ray discs. I run cable at around 18mg download. Any ideas? Thanks.......TIp Chesney
Posted by tches on
5 Related Answers
otacon
Damen Wong
  • 1950 Answers
SOURCE: No Audio
Your receiver is the Denon AVR 2105 and not the Sony STR-DG510 5.1 Channels Receiver?
Posted on Jan 20, 2008
Anonymous
  • 3 Answers
SOURCE: No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Posted on Jan 27, 2008
Anonymous
SOURCE: sony str-dg510
Why dvd sound does not play on sony str-dg510?
Posted on Feb 02, 2008
Benimur
Louie Role
  • 6966 Answers
SOURCE: MY JOB DEPENDS ON THIS!!! SONY DSR PD170 AUDIO PROBLEMS
Appreciate the direct "Ask Me".
The Sony PD170 is not an everyday equipment, nonetheless, I will assume that on the Sony DSR PD170:
  • the Samson UHF M32 receiver is plugged to Audio 1;
  • boom mic is plugged to Audio 2; (or vice versa) and
  • Both Audio 1 & 2 are using the XLR connectors.
Assuming that your boom mic is a conventional dynamic, on the Audio Control Panel, pls set:
  • INPUT 1 -
  • MIC CH SELECT CH1&CH2
  • INPUT LEVEL MIC
  • +48 OFF
  • INPUT 2 -
  • INPUT LEVEL MIC
  • +48 OFF
This is of course assuming that both the boom mic and the output of the Samson UHF M32 receiver are set to MIC level. In some instances the Samson UHF M32 receiver requires a LINE setting. The only time the +48 is set to ON is when the mic that is used/plug in requires phantom power such as condenser types. If the mic or the Samson UHF M32 receiver requires power then this should be switched ON otherwise, there will be no audio coming in. Though most M32 uses a 9 volts battery.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 11, 2008
Anonymous
SOURCE: Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Posted on Dec 11, 2008
Sony Airband 8. SN43884. Basically very little volume in all freqs. New batts. Squelch full down volume full up. Even tried outside 6v AC charger. All connections proper.
Here's a GREAT idea! BECAUSE this is such a nice but older Sony... "I" would use a Blu-Tooth SPEAKER with a AUX speaker input! LOTS of AUDIO and VERY inexpensive too!
OR I recently bought a BlueTooth TRANSMITTER/RECEIVER that has a 3.5mm" Jack right from it's body! Depending on the 'mode' it's in ~ it will TRANSMIT audio (like from your Sony) to a Bluetooth Speaker! (In it's second mode it acts like a BT RECEIVER.)
Here's a official title of another:
Mini Bluetooth 3.5mm Music Audio AUX Wireless Transmitter eBay: 322589063752 and it's about $7!
This puppy is a Bluetooth TRANSMITTER only.
"This device can transmit music from your media devices(smart phone, iPad, mp3, CD/DVD player , TVs and more) to your Bluetooth-enabled equipment (bluetooth speakers/Bluetooth headphone, etc) simultaneously"
THEN there are THESE "3 Watt" BLUETOOTH RECEIVERS for UNDER $2 ! I KNOW! Hey man ~ just pick your color!
eBay: 112673621308 DANG ~ I'm going to order some now!
MMMmmm try earphones? How is the volume then? Plenty?
ALSO earphone jacks become dirty and the contacts that SWITCH THE SPEAKER OFF become poor conductors that starve the speaker for volume... anything more than this MAY constitute a MAJOR repair cost...
SO KEEP your SONY and consider the options!
ANTHONY
Dec 24, 2017 | Sony Radio Communications
Sharper image indoor/outdoor wireless speakers and transmitter has no audio.
First, determine if the TV device is putting out sound by plugging in a headphone into the audio out of the TV. If audio is there then the
transmitter and wireless speakers system may be at fault.
You can also plug in a CD player playing a disc into the transmitter to see if that source then transmits the audio.
Aug 21, 2012 | Audio Players & Recorders
Bought a used sony str de845 with rm adu007, need program manual for rm.
If the remote is functionally the same as the original RM-LP204
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
Apr 11, 2011 | Sony STR-DE845 Receiver
Voice recognition on motorola t5500
That means that it will Transmit, like pressing the "Talk" button, BUT ONLY when it hears the "Voice" it was "Trained" on. So this is so No-one else could use this unit. With this method. You "Identify" yourself, and after that every-time you speak, the Transmitter is keyed, and the channel is opened and the voice sent, when you stop talking,it goes back to receive, again. Some are less sophisticated, in that they are really a "Sound Switch" and when the unit "Hears" a "Voice" it, switches OFF receive, and ON the transmitter, and Transmits the audio out.
Apr 15, 2010 | Motorola Talkabout T5500 (7 Channels)...
I have a long range wireless cam with a transmitter and two receivers. They were working fine for awhile, but now I can only get very ''fuzzy'' images and audio on one receiver and no image on the other....
most wireless camera's have multiple channels, have you checked to see that they are it sync. ie if camera one is on channel 2 is the receiver on channel 2 as well??
Dec 13, 2009 | Home Security
Terk wireless transmitter
Hi Sleopard,
Wireless transmitters should allow broadcasts of a single source such as a VCR, DVD player, or cable boxes. They normally wouldn’t be able to transmit something like a cable signal to your television. One way this could work is if you connected a cable box right below your outlet and then connected the cable box to your transmitter. If your transmitter has a infrared extender you may be able to change channels by pointing your remote at the wireless receiver.
Cordially,
Agent Jon
Go Ahead. Use Us.
Apr 13, 2008 | Televison & Video
No sound transmitting from Soundstation EX wireless mic # 2201-00699-002
confirm that you select aux input in your soundstation2.-if your problem excit change audio cord between receiver output and the aux.
Oct 17, 2007 | Polycom SoundStation EX (expandable)...
Sony BRAVIA® DAV-HDX576WF Theater System with Wireless Speakers Logo
74 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
