Question about Maytag Washing Machines
My washer, A612S, does everything correctly but SPIN in the spin cycles. Both belts underneath are fine. The motor pulley spin fine when in the spin cycle, but the belt doesn't. When I turn it off (pull/push the selector knob), the tub pulley spins fine. When I turn it back on, it freezes up.... almost like the brake (if it has one?) is ON when it should be off, and off when it should be on! You start to smell the belt burning. I don't see a solenoid for a brake (like my old Norge had)... maybe the brake is part of the transmission? Like I said, everything else works (agitates fine, water come in and goes out fine...knobs moves thru all the cycles), it just doesn't spin. Any ideas??? Thanks Jim
Posted by wq2121 on
  • wq2121 Jul 18, 2011
    I would agree if the tub pulley was frozen all the time, but the only time it freezes up is when the washer is on. When the washer is off, the tub pulley under the machine turns freely! That is what is so weird about this issue!
Gene Meier
  • 2,341 Answers
The brake it the drum directly above the transmission pulley it is not intergrated into the trans.
in my almost 30 years of repairs in that old and very reliable machine i would find where a article of clothing and floated over the inner tub and has wedged itsefl between the inner and outer tub, their is enough clerance between the tub and tub cover where you could get finger into it and run it around the tub and feel if a piece of clothing is caught. if that isnt the problem then the tub bearing is ceased up and would require repalcing it and the tub seal
Posted on Jul 18, 2011
    I would agree, if the pulley for the tub underneath the machine was frozen all the time. I checked, no clothing stuck between tub and tub shell. When the machine is off, that pulley turns freely. As soon as I push/pull the knob and the machine is on, that pulley ceases up. I think the brake must be in the pulley, as it is a HUGE pulley and maybe a clutch inside of it. There is no drum directly above the pulley.. the transmission is directly above it. Hope this helps. I could send pictures if it helped...JIm
    WQ2121 at sbcglobal.net
  • Gene Meier
    Gene Meier Jul 18, 2011
    can the trans. pulley be turned both directions? its can be turned by hand with the belt removed by turning it one direction it will be in the agitate mode and when turned the other direction itwill spin.their is no clutch and thanks for offering the pictures but i know it very well having been a appliance service tech for so very long
Washer motor spins but not the belt in spin cycle only,
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Will agitate but won't spin
You could have a bad door switch, always make sure your appliance is disconnected from it's power source before performing work on it, if the door switch is defective your washer will do everything but spin in the spin cycle, it's usually located at the door latch, when the door is closed it pushes the door switch in, you can check it by removing the switch and doing a continuity test on it with the switch in the closed position, or it could be a broken drive belt, some washers use two belts instead of one, check to see if your washer has more than one belt, there are other things it could be that are more complicated such as a bad transmission, bearings, motor, or clutch. which could involve calling a repair man.
Mar 16, 2009 | Maytag PAV2300 Top Load Washer
Non-spinning washer
Have you checked the motor? Make sure that the motor is turning properly and also make sure that your belt it not to tight. It should have some give in it. If none of that works then look at the main bearing under the pulley on the drum
Feb 10, 2009 | GE WNSE6280BWW Top Load Washer
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer belt is loose, & seem to slip at start of spin cycle.
there are several drive belts for this model... check here to see if the one you are fitting is the correct one... also,is the tensioner siezed? causing the tension to be too slack therefore allowing the belt to shred at speed?
check here .. http://www.partselect.com/AppliancePartList.aspx?Brand=Admiral&Appliance=Washer&ModelNum=&Type=Belt&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Dec 03, 2008 | Admiral AAV7000A
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Maytag Washer will not spin
Pull the unit forwardand lean it back about 45 degrees. You'll have to play with it a bit, but once it's far enough out, it will lean back without you having to hold it. Remove and inspect the belt(s) are they in good condition? Next, check the pulleys (wheels) underneath. Do they turn? One is for your pump, one is for your transmission and one is for the motor. (in case one doesn't turn, you'll know what portion needs to be worked on). Also check the track on your pulley the belt sits in. Is it dammaged or worn?
Jun 02, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Sheldon Dedek
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
