Question about HP LaserJet CP1515n Printer
CALIBRATE THE PRINTER
Use the menus
1. Press OK to open the menus.
2. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the listings.
3. Press OK to select the appropriate option. An asterisk (*) appears next to the active selection.
4. Press the Back arrow ( ) button to scroll back through the submenus.
5. Press X to exit the menu without saving any changes.
Color Calibration
? Power On Calibration. Specify whether the product should calibrate when you turn it on.
? Calibration Timing. Specify how frequently the product should calibrate.
? Calibration Mode. Specify the type of calibration the product should use.
? Normal
? Full (slower)
Full calibration improves the color accuracy of photos printed on 100 x 150 mm (4 x 6 in)
HP Color Laser Photo Paper.
? Calibrate Now. Set the product to calibrate immediately.
NOTE: You must click Apply before your changes take effect.
Posted on Jul 18, 2011
SOURCE: Printer keeps showing : Press
PRESS SET UP & OPTIONS AT THE SAME TIME. WILL CLEAR MESSAGE.
Posted on Oct 22, 2008
SOURCE: will not align
I tried this and it worked. First, disconnect printer for about 5 seconds and then reconnect. Then hold down together "Setup" and ?ptions""buttons for two seconds. Then release. My problem was solved
Posted on Apr 27, 2007
SOURCE: ALIGN CARTRIDGES
Unplug the printer, wait 30 second and plug it back in. Sometimes that resets it.
Posted on Jul 23, 2008
SOURCE: dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges
Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Posted on Feb 01, 2009
SOURCE: printer Align keeps failing after I chnaged the color cartridge
Are all the inks printing? If not you need to get all colours working before correct align can take place Have you tried cleaning the gold cartridge contacts? Wth a little distilled water, cotton bud and then let dry before reinstalling
Posted on May 29, 2009
Oct 26, 2011 | Lexmark X2690 All-In-One InkJet Printer
Oct 23, 2010 | HP LaserJet CP1515n Printer
Aug 24, 2010 | Office Equipment & Supplies
Aug 22, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Jul 08, 2010 | HP PSC 2210 All-In-One InkJet Printer
Nov 12, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Nov 23, 2008 | HP Office Equipment & Supplies
Aug 18, 2008 | Office Equipment & Supplies
Aug 05, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Aug 01, 2008 | Office Equipment & Supplies
6,271 people viewed this question
