SOURCE: no sound through Panasonic SA-HT930 surround system
I've had similar problems in the past. With audio problems trace the problem from the source to the amp.
1. What output is the cable box using for audio, digital or analog?
2. Is there a setting in the cable box to switch between digital and analog?
3. Once you have determined the output of the cable box check to make sure that it's going into the right output on the panasonic
4. This is where the problem usually is...what is the receiver expecting for sound, analog or digital?
5. Switching between the sources...the sound should be on one of them.
SOURCE: No sound from TV to home theatre system
hdmi does sound to,,,try if the reciever has hdmi,,unhook the optical cable and try it by itself,,and vise versa
SOURCE: Panasonic SC-HT900-problems with surround sound mode and digital input
I have the same problem with my RCN system
SOURCE: Sound distortion comes and goes...
First of all, try to have this repaired under warranty. Usually these sets have a 1 year warranty. Second, make a recording of the problem. That will help the servicer to understand the problem.
If you are not successful at the warranty repair, the first thing to look for is a power supply problem or poor connections at the audio amp area. I will attempt to locate more details while you persue the warranty claim.
Please keep us posted.
Thanks,
Dan
SOURCE: i have a panasonic sa-ht75 surround sound system,
You have probably solved this problem now, but incase you havnt, we had the same problem, the wrong lead came with ours, you need to plug the red and white into the audio out, and this should solve the problem, hope this helps
