Computers & Internet Logo
Posted on Jul 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It appears that my screen saver has not been enabled. If I am away from my desk for an extended period the screen saver is not activated.
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 68 Answers
  • Posted on Jul 18, 2011
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
68
Questions
0
Helped
8974
Points
173
To enable the screen saver in Windows XP, right-click on the desktop and choose Properties. Click on the screen saver tab and choose a screen saver. Set the wait time, click Apply and Ok and you're done. for Windows Vista and 7, use the following directions from :http://windows.microsoft.com/en-US/windows-vista/Change-screen-saver
  1. Open Screen Saver Settings by clicking the Start button It appears that my screen - 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Screen Saver.
  2. Under Screen saver, in the drop-down list, click the screen saver you want to use.
  3. Click Preview to see what your chosen screen saver will look like.
  4. Click OK.
    Thank you for using FixYa!
1helpful
2answers
How do you get Windows 10 free update from Windows 8 to operate the screen saver?
How to customize Screensaver in Windows 10
RECOMMENDED: Click here to fix Windows errors and optimize system performance
There were times when computer monitors used to suffer from image burn-in issues caused by showing the same image for a long period of time and people used to install a screen saver to avoid the issue. The computer screens today no longer face the burn-in issues, but people still use the screen saver on their computer systems for fun's sake. Windows 10 comes with a six built-in screensavers. Let us see how you can customize screensavers in Windows 10.
Read: Are Screensavers necessary and still needed.
Screensaver Settings in Windows 10 You can get to your screen saver settings directly by typing 'Screen Saver' in the taskbar search box in the lower left corner of your system. Click on 'Change Screen Saver' and it will take you the Screen Saver settings right away where you can adjust the settings according to your own preferences.
Alternatively, right-click on your Windows 10 desktop, and select Personalize to open Personalization settings. Next click on Lock screen in the left pane.
Scroll down the Lock Screen settings and click on Screen Saver Settings. The following window will open. Here you can adjust the settings according to your preferences.
By default, Windows 10 offers the following six screensavers - 3D Text, Blank, Bubbles, Mystify, Photos and Ribbons - nothing new here. Select the screensaver from the drop-down menu and change its defaults Settings, if any are available.
For instance, the 3D Text screensaver lets you customize the text as well as a few other options.
The Photos screensaver lets you display your favorite photos as a screen saver.
Once you are done, click on save and exit.
Create Screen Saver Settings Shortcut
If you access the screensaver settings frequently, you can create its desktop shortcut as follows: However, it is easy to change the settings but if you change your screen saver often, it would be better to create a Screen Saver Settings shortcut on your desktop.
To create the shortcut, you have to right-click on your desktop and click on New > Shortcut.
Type control desk.cpl,,@screensaver in the location space in the wizard.
Click Next and give a name to your shortcut. Click Next and you are done. Give it a suitable icon of your choice.
Use this shortcut to change or adjust your screen saver settings whenever you want, quickly.
You can also create a shortcut to launch or change Screensaver state for a specific screensaver.
How to turn off screen saver on an Acer Aspire v5
hi
right click your desk top and select personalize
on the appearance and personalization page
at the bottom right corner is the screen saver click on it
screen saver drop down menu change it to none and press ok
cheers
Hp pavilion all in one AMD goes to sleep after 1 minute idle then asks for password to open up.. how to extend idle time to 2 hours
What you are experiencing isn't "sleep" mode, it is the screen saver. If you have WINXP, right click on a clear area of the desktop, and select "Properties". When the DISPLAY PROPERTIES window appears, select the "screen saver" tab. Change the "WAIT" time to the time you wish the scrren saver to delay. If you don't want to have to login after a screen time out, uncheck the "On resume, display Welcome Screen" box.
1helpful
How to disable energy saving on KitchenAid Range
The Energy Saver Mode deactivates the display to reduce energy
consumption.
To Activate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver on."
will appear in the upper text area.
2. The setting will be activated after 5 minutes.
Any cooking function may be used with the range in Energy
Saver Mode by simply selecting the desired function.
To Deactivate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver off."
2. The clock will reappear in the display, and the range can be
operated as usua
Please check my youtube video to understand my problem http://www.youtube.com/watch?v=43ppZNyMACY
Great presentation of your problem.
One thing I would check is the screen saver. You say as long as you use the computer it looks normal. Look at your screen saver settings to see if the lined appearing coincide with the screen saver time.
With computer parts, failure on a periodic basis (based on time) usually indicated a heat problem. This does not appear to be the problem in your case, as you say you can use the computer for an extended period without a problem. This is why I was suggesting a screen saver problem. You might even try a different screen saver just to test this. Possibly the part of windows that controls the screen saver (and don't ask me where that is, 'cause I haven't a clue) is corrupt.
Good luck.
My screen has horizontal colored lines over the entire left hand side of the screen during a 2-3 minute warm up period when I turn on the TV. It goes away after that and is fine otherwise until I turn off...
The tv board call the T-CON decoders board is dying,that why this problems are appearing.This T-CON decoders board it sit right on the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
There is an icon that came up and it looks like the old fashioned film you would put in cameras. Looks like 2 circles with a line underneath. Ever since this popped up when my flip phone is closed the time...
that could be the indicator for "you have voicemail messages waiting" -- It looks like a little tape cassette. Pick up your voicemail and it will go away.
as for the time display on the front screen, check that you have the screen saver enabled - Settings, Mini Display, Screen Saver, Digital Clock (or analog clock if you prefer), then check again to make sure it is set to On.
1helpful
If I leave my computer unattended for maybe 15 min. this monitor turns itself off. Is there a way to fix that? Thanks, brumeister
Screen savers can help protect your monitor from wear by showing a constantly changing display when your computer is not being used. Screen savers can be simple, like the Blank screen saver that turns off your monitor to save energy. To change your screen saver 1. Right-click your desktop, and then click Properties.
2. In the Display Properties dialog box, click the Screen Saver tab.
3. Click the Screen saver drop-down box, and then click a screen saver.
4. Click the Preview button to see how the screen saver will appear on your monitor.
5. Move your mouse or press a key to return to the Display Properties dialog box. To try a different screen saver, return to step 3. 6. Click the Settings button to change the standard behavior of the screen saver you selected. (Each screen saver has its own settings dialog box.) Then, click OK.
7. In the Wait box, type the number of minutes the computer should wait to start the screen saver after you last touched the keyboard or mouse.
8. If you are the only person who uses your computer and you are not concerned about security, clear the On resume, display Welcome screen check box. Otherwise, leave this check box selected. Note: If your computer is joined to an Active Directory, the Fast Users Switching feature will be disabled. This is a common change made to computers used for business, and it happens automatically when a computer joins an Active Directory domain. However, disabling the Fast User Switching feature is not the default setting. Almost all computers in home environments will have Fast User Switching enabled. When Fast User Switching is enabled, you'll see the On resume, display Welcome screen check box. If you're part of a domain, you'll see the On resume, password protect check box.
9. Click OK.
Microsoft wireless 4000
Screen saver mode, as you know, is entered when the computer senses no activity (including mouse) for a defined period of time. for some reason, the computer thinks there's been some kind of activity. If you have an extreamly sensitive mouse, vibrations could be being picked up "tricking" the computer into thinking there is activity.
The other possibility is that the computer might not be able to respond to the mouse if it went into screen saver mode (perhaps a preference setting with the wireless mouse) and has decided that while operating using a wireless mouse screen saver will be deactivated. Look into your preferences or settings relating to the wireless mouse.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
