Microwave Ovens Logo
Anonymous Posted on Jul 18, 2011
Hobart slicer 2912. The slicer works fine on manual but the automatic mode has stopped working. thinking it may be the motor but not sure,,, any idea on how to identify the part that needs changing?
Marlowe Amoguis
Level 2:
Sergeant:
  • Expert 405 Answers
  • Posted on Jul 18, 2011
Marlowe Amoguis
Expert
Level 2:
Sergeant:
Answers
405
Questions
0
Helped
105756
Points
988
HI. Have you tried checking if you can hear the motor is rotating. There are actually gears connecting the motor to the blade.The motor on it is just a dc motor.voltage usually ranges from 20 to 50 volts dc.If you can removed the cover and check if the motor is rotating while the unit is plugged on though this is not advisable to do this but for the sake of observation and making sure that while doing this you haven't touched any of its auxillary parts.Try to check how the gears are moving..Hope this helps.Thank you for choosing FIXYA.
Baxter rotating oven Model No. OV-851G stopped rotating
Hi Sam-
I found this link.
https://www.hobart.com.mx/pdf/ManualOper/F31199.pdf
On page 20, it talks about "Emergency Tray Operation"-both Electrical Tray Operation and Manual Tray Operation.
Hope this helps.
1helpful
Samsung model RB1844SW. Refrigerator and freezer stop cooling. Unplugging and plugging back in resets and it works fine for 7-8 hours before the same problem occurs.
Check if the circulation motor /fan which blows air around the inside is working . It is located near the top of the refer. also check if air is circulating in the freezer there is a main fan in there which sends cold air from the freezer to the refer. If either fan wears out sometimes it runs for a while and sometimes not. the motor chatters sometimes before it dies. I have had defroster control timers go bad, causing this problem too, because the refer goes into defrost cycle and doesn't go back to refrigerate mode till the defrost cycle is over. if the timer clock stops it will do the same thing, and not go in to refer mode. Good luck, Bill
I have a Kitchen Selectives meat slicer Model SL-50 and the dial on the back that determines the thickness of whatever is being slices is not working. I see that underneath there are two white plastic...
I have the exact same meat slicer & I would love to know what those plastic scescrews are for. Did you ever figure it out? The instruction book doesn't even mention them.
I need an instruction manual for Ronson Food slicer model 87003 please
Bronte,
Did you ever get a manual for your Ronson food slicer, model 87003?
I have 1 of these slicers & am needing a manual as well.
2helpful
Where can a get a manual for the v slicer mandoline? there wasn't one in the box it came in?
hello you can find your slicer manual at this link click here http://www.zylissusa.com/v1/PDF/Instructions_Mandoline.pdf if you have any further questions please message me back and please remember to also rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Cobart Automatic Meat Slicer is not working on Automatic mode
To operate the slicer in Automatic mode . . . Rotate the Speed Selector Knob to the desired speed; make sure the Carriage is in HOME position (all the way forward); make sure the Lever is on the Manual position (pointing down); turn the slicer on; start the carriage drive unit by rotating the Lever to the Automatic position (up and to the right). Either of the two speed selections can be used to begin Automatic mode. The speed can be adjusted at any time by rotating the Speed Selector Knob. To stop the drive unit, rotate the Lever down and to the left - to the Manual position. ------------ If you slicer is set on proper automatic mode and still not running on automatic mode then the problem relates to internal motor or the selector knob. But try reset before this. Push the reset button underneath the slicer near the right-front foot if the carriage motor overloads. The reset helps in some problems.But if its not helping then internal connections of selector knob has to be checked.Of the same with motor,the connections of motor to the selector for automatic mode has to be checked.---------------- This will help.Thanks.Helpmech.'
14helpful
2answers
Farberware v-blade mandoline slicer instructions - nothng in or on box - how do I use and put together
I bought a faberware V-blade Mandoline slicer and I would like to have an instruction manual for the blade usage please
Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
We're happy to help and we appreciate your thoughtful rating of our answer.
2answers
GE jvm1190 above the range microwave /convection (2001 model)
It sounds just like the magnetron is bad, overheating and opening the thermostat. This is how it would work if that were the case.
One other thing is to be sure that the cooling fan is running and that you feel air flow.
You should check the air filter and grille, as well as the outside vent for any blockage.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
