pick the last program you put on ????
then you hold the button with the clock on it for five seconds the lock should now be off
please leave feedback if it helps
I would suggest that you remove the motor, and check the brushes for wear.
If they are less than 3 or 4mm long, then they need to be replaced.
Hope this helps.
check the manual . you can take the key mode off with the instructionsprobably a press and hold for 2-3seconds thing .If you dont have the manual you can get it from thermador. com they will order it for you. you will get it 2-3days. let me know how you made out:)
I had the same problem- machiine not spinning and a few days later not turning at all. Display would go from 11min to 1min.
I did 2 things - 1) changed the brushes on the motor- cost £7.50 .
2) whilst working under the machine disconnected pipe from drum to pump and emptied it- found 2 coins in the bellows.
