Question about Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack
My fairly new P103 battery reads fully charged on the charger but does not power tools - completely dead! I've only had the battery a few months, and it worked earlier. What is the expected life span for a lithium battery? Shouldn't it be more than a few months of light home use?
Posted by jem99 on
2 Related Answers
Anonymous
  • 127 Answers
SOURCE: can I use the ryobi
No. The P110 is for NiCad batteries. Any of the Li-Ion chargers like the P113 are backwards compatible and can charge either but do not try to charge Li_ion batteries in a NiCad or NiHi charger.
Posted on Dec 27, 2010
Anonymous
SOURCE: I bought 2 P103 lithium
Yes, P103 will work with any 18V Ryobi tool
Posted on Feb 22, 2011
No light comes on my charger when i plug in my new p103 battery into charger no 1423701?
does the outlet work that the charger is plugged into... is the battery completely dead and the charger can't see it... is the charger even plugged in... or is it even any good ???
Oct 23, 2013 | Ryobi Multi-Volt Battery Charger
Lithium ion battery does not last as long
There is no such thing as a memory system in your battery. If you charge the battery until the green light on the charger comes on, that is as much as the battery can/will safely charge to. With Lithium batteries, they will fully charge whether they are at 75%, 50% or 10% capacity when placed on the charger and discharge to 0% if you use them that long. If you need the battery before the green light comes on and you use it, it will still fully charge when replaced on the charger. All batteries do discharge at different rates. Most not noticeably but a few will discharge fast enought to be noticable. If it affects your usage of the tool, you may want to exchange it or get it replaced under warranty because it will only get worse with age.
Mar 03, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
Battery charger reads battery full when dead
The battery is no longer good. You will need to buy a new battery. Don't over charge your batteries. They all vary. Expensive cordless tools will come with a charger that shuts off automatic to prevent over charging. I own cheap Skill drills that has served me well. These batteries lasted over 11years. It makes no sense. They should not have lasted more than 5 yrs., even 2yrs. I make sure I never over charged them, but they should not last that long. Freaky. Your battery is dead forever, sorry. I have others just like yours waiting to be recycled.
Sep 29, 2012 | GRACO INC TrueCoat 18V Lithium Ion Battery...
Ryobi batteries P103 (2) or P104
The physical differences between two models of Ryobi batteries is:
- The P103 (Part Number 130429008) is a 1.5 Amp/Hour (a measure of how long a battery lasts on a charge) battery. If totally discharged it takes about 15-20 minutes to charge back to full. It is lighter than the P104 because it has half the cells inside. Lighter, quicker to recharge, quicker to discharge, shorter lifespan.
- The P104 (Part Number 130429017) is a 3.0 Amp/Hour battery. It takes about 30-35 minutes to charge it to full if fully discharged. Slightly heavier, longer time to discharge & recharge, longer lifespan.
Considerations:
- No difference between batteries in the performance of your tools.
- The number of times you discharge and recharge a battery determines a batteries lifespan. That's why most manuals will tell you to fully discharge a battery before putting it on a charger.
- If you only have one battery you cannot use your tools while it is recharging. On big projects you have to have two batteries.
- The weight difference between batteries is negligable unless you are working with the tool in your hand for extended periods.
Mar 04, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
Feb 18, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
What Ryobi batteries p103 or p104 will a battery charger that came with my p100 batteries charge? Or will the charger work with these batteries?
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Jan 11, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Two brand new Hitachi BSL1815X Lithium Batteries won't recharge (UC18YGSL charger and DS 18DSAL drill)
These batteries have big problems that Hitachi doesn't address very well. Unlike NiCad batteries, Lith-Ion ones must be periodically used and recharged to retain their battery functions, i.e. if they have been sitting on the shelf at a store for an extended period of time, chances are they will be dead when bought and will not accept a charge. If they go dead i.e. no little red light on the charger when you plug the battery unit in...it's basically junk.
If you can return them or exercise the warranty do so. If / when you get new ones DO NOT completely discharge them like you would NiCads. Lith-Ion batteries do not have the "battery memory" issues that NiCads have which means you don't lose running time if you don't fully discharge the battery unit prior to recharge. Completely discharging before recharge will ultimately kill them. Use the 1815X till almost dead and then charge it. It is also recommended Lith-Ion batteries not be stored fully charged i.e. charge the 1815X fully, drive a couple bolts or screws, remove the battery unit and then put it away. Do not leave battery unit plugged into the tool when you put the tool away. This will discharge and kill the battery unit.
There are non-Hitachi substitute batteries now on the market. I'm guessing the same precautions apply but I don't own one of the replacements so I don't truly know.
The actual batteries in the Hitachi BSL 1815X are Sanyo UR18650SAX lithium ion batteries. Lithium Ion cells aren't all that easy to get commercially because of handling & safety requirements. Not certain if you can take apart the 1815X and swap out the bad Sanyo cells.
Jan 07, 2011 | Hitachi Koki Usa WH18DL Lithium Ion...
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
May 17, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Bought my phone yesterday...Battery was losing charge quickly.. battery was down to half charge after about 15 minutes of fully charging.. Was trying to let the phone die completley then fully charge it,...
Ok first of all you should never let a phone die out of charge at all.IF it dies out of charge there are chances it might charge again once you charge it but in some cases it wont, you need to boost your battery just like jump start your car.It cannot be done anywhere except some service centre. If you are not taking to your service center , then you need to buy a new battery.
Oct 08, 2009 | Cell Phones
Ryobi Two  18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Logo
145 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Marvin
Marvin
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
