Question about LG GH22NS70 Super Multi 22X SATA DVD Writer Black OEM Burner
LG GH22NS70 Super multi DVD Rewriter just used
LG GH22NS70 Super multi DVD Rewriter just used this to replace our original drive that kept erroring our cd-r discs but it wont read discs/cd rom games... click on icon and the tray opens and just keep saying put in a disc and the screen auto chanes to `burn` mode cant play the pc games.... is it cos its a `re-writer` and not a `dvd drive` ? any help would be appreciated
  • LG Master
  • 5,660 Answers
Power cable attached, interface cable attached, (Dta cable), and the small audio cable attached, plus computer on, and Windows loaded.
Windows XP:
1) Click on Start
2) Right-click on My Computer
3) Left-click on Properties at the bottom of the list
4) Left-click on the Hardware tab
5) Left-click on Device Manager
6) When Device Manager loads, left-click on the + sign to the left of - DVD/CD-ROM drives
7) Right-click on the name of the optical drive.
8) Left-click on Uninstall
A Microsoft 'squawk box' will come up,
"Warning you are about to uninstall this device"
It's okay. Click on OK.
Close all windows, go back to your desktop screen.
Turn the computer off normally. (Start > Turn Off Computer > Turn Off)
Wait 1 minute. Turn the computer back on.
You should get a pop-up out of the system tray, "Found new hardware", and perhaps another one will follow, "Found XXXX DVD drive"
No? Doesn't work?
Try using another 4-pin standard Peripheral power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(The IDE harddrive shown, is just an example of a device that uses a 4-pin standard Peripheral power cable. Mistakenly referred to as a 'Molex' power cable)
Make sure the interface cable (Data cable) is plugged in tightly.
Regards,
joecoolvette
Posted on Jul 17, 2011
Lg hl-dt-st dvd ram gh22ns70 after use alcohole 120% does not recognize dvd only cd
Uninstall Alcohol and see if it is an issue specifically with that program. It may not be compatible. You made need to update the firmware on the bios r the dvd firmware. You may also need to replace the entire DVD burner.
Oct 18, 2012 | LG GH22NS70 Super Multi Disk drive DVD RW...
Where can i get a driver for cd roms or dvd burners without buying it
These devices are Plug-and-Play devices. No need for drivers. Just simply connect it to the internal power supply, the PCI connector or SATA connector, the device should automatically be detected. If not then it calls for a new CD/DVD-ROM drive.
Thank you for choosing FixYa!
Aug 13, 2011 | LG GH22NS70 Super Multi 22X SATA DVD...
Im having trouble with my drives it wont read the cd or burn the cd or dvd
Hello there,
If your LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe does not read disc, burn cds or dvd, then it means there is a problem with the lens of the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe.
You will have to replace the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe or have the lens replaced.
Be sure not to use the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe to watch movies as that weakens the lens easily.
Hope this helped.
Goodluck
Elect_Comp
Aug 09, 2011 | LG SecurDisc 20x Internal Double-Layer DVD...
Wont read dvd video discs
1st step; Acquire/buy a cd/dvd rom drive cleaning tool kit from your local pc store.
2nd step; Install a dvd coder/decoder software, try Power DVD player software it has a trial version
3rd step; After installing the DVD coder/decoder from Power DVD player try playing a dvd movie rom disc it should work/play... hope these tips help ;-)
May 24, 2009 | LG GMA-4020B Super-Multi...
LG DVD Writer
re-install after un-install the burning application.
Nov 04, 2008 | Computers & Internet
GSA-H55L problem
your dvd writer have warranty
so you contact LG customer care is better
you can use their free service warranty
Jan 17, 2008 | LG GMA-4020B Super-Multi...
Cd driver
you do not need a driver cd for installing the driver for cd/dvd drive if you are using windows xp or any of its higher version as all the hardwares are auto detectable in these operating systems....go to device manager and scan for hardware changes
Dec 29, 2007 | LG Electronics 16x DVD and 48x CD-ROM...
LG GH22NS70 Super Multi 22X SATA DVD Writer Black OEM Burner Logo
1,083 people viewed this question
Top LG Computers & Internet Experts
Ekse
Troy Staley
Troy Staley
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
