SOURCE: SPRINT SANYO PRO 700
Hey! I just got the PRO 700. IT DOES NOT USE SIM CARDS! instead like the other sprint phones it uses the ESN/MEID number on the back. Just call sprint and tell them you want to do an ESN SWAP or SWITCH TO A NEW PHONE and they will ask you for the number under the battery. They will also walk you through activating everything including Direct Connect. It is as fast as Nextel traditional Direct Connect but it has a MUCH LARGER COVERAGE AREA FOR VOICE AND DIRECT CONNECT. Soon these phones will take control and the whole IDEN network Nextel uses will be converted to CDMA (sprints High Speed Network).
SOURCE: sanyo scp 6600 /security lock code
The standard unlock code for my Katana is 0000. Once you unlock it you can change it to whatever 4 digit numbers you would like. Let me know if this works for you, please.
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
SOURCE: My battery life on my Sanyo Pro 700 doesn't last
may be but most probably ur ic may be damaged.....
SOURCE: Hi i need a msl code for sanyo pro 700 hex
You can Try Unlock code(MSL Code) at here http://www.mobile-unlocker.com/sanyo-pro-700/rs2wp9/
