Please check ur charger's hole (phone or charger). and - may touching:) thats y ur phone switching off:)
Have you tried with another working Battery? That should be your first option. If you know how to use a multimeter to test the battery, give it a try. Also with the multimeter, check the continuity from charging port to the charging connectors inside the battery compartment. Also check the input voltages on the charging connectors after a charger is plugged in to the phone. If nothing works, then it's possible that the charging ic or the power ic is dead. You'll need to take it to the service center.
Let me know if you need further help (with more details).
Good Luck.
Thanks for using FixYa.
1 - Switch on your Nokia E71 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E71.
3 - Compose #pw+CODE+1#.
4 - The Nokia E71 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E71 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E71
Each Nokia E71 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia E71 mobile phone using the form above.
