Hi.
When the cycle hangs it means that because of a fault the conditions to advance are not met.
If the washer hangs at start (filling), then there is either a problem with water pressure, blocked inlet, or water flowing back from drain hose because of incorrect hose settings (called siphoning).
If machine hangs mid cycle, then it is often a temperature related problem. Check thermostat and element or check hot inlet and thermostat if dual inlet. Testing requires disassembling and use of the multimeter.
If machine hangs mid cycle or end of the cycle (before spin), then it can be drain system. Check drain hose, drain filter attached to pump and check the pressure switch.
Most machines have a service sheet hidden inside the control panel assembly. The tech sheets shows how to run a diagnostic cycle that will tell where the problem is.
Most common faults resulting in long cycle are heat-related and drain problems.
Regards.
Ginko
