Question about KitchenAid A-9 Electric Burr Grinder
I need to order the acorn nut for a kitchenaid A-9 burr coffee grinder
Posted by jruoff on
Bill Frederick
    New Friend:
    Problem Solver:
  • 5 Answers
I found this while searching for shear pins http://www.partselect.com/PS984110-Whirlpool-9707016-Nut-Acorn.htm
Posted on Aug 17, 2011
Where can I get an Kitchen Aid A-9 burr grinder repaired?
Softly Scrambled: Kitchenaid A9 Grinder Refurbishment.
softlyscrambled.blogspot.com/.../kitchenaid-a9-grinder-refurbishment.ht...
Mar 1, 2014 - This is an original A9 from the days when Kitchenaid was owned by Hobart. ... Yes, it worked and would grind coffee, but the motor seemed to labor and the grinds were ... I am now doing this for mine, but I can not for the life of me get to the bushings. Does ... I don't recall a ball bearing from repairing my A9.
KitchenAid Burr Coffee Mill KCG200 (aka A-9) - Automatic Washers ...
www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?44466
Jan 13, 2013 - 49 posts - ‎12 authors
I'll definitely use that cleaning method if I can't get the grinding mechanism .... I'd try lifting the lower burr assembly out with the aid of two flat ...
Kitchenaid A9 Coffee Grinder - HubPages
hubpages.com > Food and Cooking > Beverages
Sep 20, 2013 - Where can I buy a retro Kitchenaid A9 Coffee Grinder? ... are paying for (is it new in box, has it been used for 20 years, or does it need repair).
KITCHENAID A-9 INSTRUCTIONS MANUAL Pdf Download.
Dec 21, 2015 | Coffee Makers & Espresso Machines
No grinding
try check those blades? maybe, its loosen up..if it does,refit it but be careful you might injure yourself.
Jan 24, 2008 | KitchenAid A-9 Electric Burr Grinder
How do I clean the inside of the coffee grinder kitchenaid model A-9
Instructions Things you need
  • Soapy water
  • Screwdriver
  • Burr cleaning brush
  • Damp cloth
1 Turn off your KitchenAid coffee grinder and unplug it from the socket.
This reduces the risk of injury while cleaning the appliance.
2 Turn the bean hopper, located at the top of the grinder, counter- clockwise and remove it from the appliance.
3 Slide the coffee bin toward you to remove it from the grinder.
4 Wash the hopper, hopper lid and the coffee bin in hot, soapy water. Rinse and dry these parts after cleaning.
5 Locate the grind control dial on the front of your KitchenAid coffee grinder. Screws are located to the left and right of this dial.
6 Turn the screws counter-clockwise with a flat head screwdriver to remove them from the grinder.
7 Pull the entire faceplate assembly gently toward you and out of the KitchenAid coffee grinder. The faceplate assembly is attached to the back of the grind control knob.
8 Pull out the burr shaft assembly, which is right behind the faceplate assembly.
9 Brush the burr shaft assembly with the burr-cleaning brush included with your KitchenAid coffee grinder to remove any debris or remaining grinds.
10 Reassemble the KitchenAid coffee grinder by returning the burr shaft assembly and faceplate assembly to the appliance. Tighten the screws with a screwdriver to hold the assemblies in place.
11 Wipe down the exterior of the coffee grinder with a damp cloth.
12 Return the clean coffee bin, hopper and hopper lid to your clean KitchenAid coffee grinder.
Aug 17, 2012 | KitchenAid Model A-9 Coffee Mill Grinder
I have just replaced the burs and have re assembled the grinder? Even on fine setting the grind is coming out like wood chips . I have checked the blades and the are only a 1/3 turn away from contacting...
Hi
I would suspect that the burrs have never touched. There has to be some coffee grounds in the threads that is preventing the burr assembly form going in any farther. Remove the burr assembly and check the threads inside the chamber. If there is any black coffee residue it has to be removed. It sometimes has to be chipped out of the threads. We used a dental probe to remove it. Then a tooth brush. When reassembling the burr assembly turn all the way in until you see the acorn nut in the center rotate. STOP. Back the assembly back until the nut stops rotating. That is ZERO. You can install the bean hopper with the zero facing the mark. You can also move the assembly a little counter clockwise, but not clockwise, to line up the screw holes. Make sure that you have the hopper stop in place before tigntening you screw down. Then turn the bean hopper to 7 and test.
Apr 29, 2011 | Rancilio (RAROCKYND) Grinder
A-9 Grinder Diagram
Search online for "Kitchenaid 8204548" that's the parts list. It should take you to a Sears page with the parts you need.
The part number for the Acorn Nut is 9707016.
Oct 13, 2009 | KitchenAid A-9 Electric Burr Grinder
Cannot get the grinding ring option to turn
This is a set screw. You need to take this out.
You can access this to either clean the burr
grinding wheel. Maybe this needs changed.
If you google the Kitchenaid A-9 Burr grinder you can get instructions to download on this machine.
Mar 05, 2009 | KitchenAid A-9 Electric Burr Grinder
Parts and Grind Selection
The current Kitchenaid A9 burr grinder glass jar is interchangable with the original Hobart/Kitchenaid A9 glass jar; therefor, the gasket should also interchange - contact Kitchenaid customer service to order a gasket.
Setting the grind is accomplished by grasping the body of the ginder in one hand and the grind-selector ring (collar that the jar screws into) in the other. Hold the base tight and turn the selector ring clockwise for a finer grind, counterclockwise for coarser. Be careful not to completely unscrew the selector ring; if you are not sure how much adjustment is left, screw it all the way clockwise until it stops (finest grind); then, back it off, up to one full turn to make the grind coarser.
The selector ring has the words coarse, medium and fine cast into it; these are rough postition markers. There is a triangle cast into the body of the grinder, just above the brand name, that can be used to diral in a preferred level of grind. I use a medium-coarse grind for drip coffee makers; to do likewise, position the selector ring so that the triangle is pointing midway between the words coarse and medium.
Dec 21, 2008 | KitchenAid A-9 Electric Burr Grinder
KitchenAid A-9 Electric Burr Grinder Logo
305 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
graybeard32301
Ismael Rodriguez...
Marvin
Marvin
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
