Question about ASUS K8V-X SE Motherboard
Hello! have an Asus K8V-X! I do not recognize SATA HDD! I need the manual language Romina motherboard! Thanks!
Posted by aurelvlascea on
James Miller
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 2,226 Answers
If you go to asus web site you can download all drivers and manual there. go to support then go to motherboads type in board than download them there ok jim
Posted on Jul 17, 2011
I have K8V-MX motherboard. I am planning to buy a 1TB SATA HDD Will this support ? Thanks! Madhusudan
Your model KV8-MX motherboard does not have a SATA controller.
To install a 1Tb SATA hard drive you need to install a PCI SATA controller and then connect the SATA hard drive to this controller board.
Aug 21, 2010 | ASUS K8V-MX Motherboard
SATA HDD is not detceted properly
As far as I can remember, the VIA VT8237R southbridge used on this board has a bug, causing it not to recognize SATA II drives.
You may be able to configure your hard drive to use the slower SATA 150 mode (1.5 GBit/s or 150MB/s) by setting a jumper on the drive. Unfortunately, this is not supported by all models - check the jumper description on the drive.
If the drive doesn't offer this feature, you might consider adding a SATA controller like this one (you may be able to find better and cheaper controller cards at your local computer store).
Mar 22, 2010 | ASUS K8V-MX Motherboard
I'm wondering if my ASUS K8V-X motherboard will support a 320 GB SATA hard drive.
Check is there ports available for connect SATA HDD. If yes it will support .
Thanks.
Oct 14, 2009 | ASUS K8V-X Motherboard
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
PATA SATA PROBLEM
This motherboard does support SATA. Check out the specs on the ASUS website:)
http://www.asus.com/products.aspx?l1=3&l2=14&l3=225&model=754&modelmenu=1
Dec 30, 2008 | ASUS K8V-MX Motherboard
K8V-MX motherboard+HDD size limit
yes the mother board supports SATA However if you connect large Disks to the SATA connectors they are recognized correctly with full size. So leave your 500g and less HDs on the IDE and the big ones on the SATA. you can check this link for the manual for more information ftp://ftp.chiligreen.com/Desktop/Manuals/manual_a_k8v-mx.pdf hope this helps .thanks and Godbless pls appreciate by rating as fixyaa
Oct 03, 2008 | ASUS K8V-MX Motherboard
AMD, ASUS K8V-MX MOTHER BOARD SOCKET 754 AMD
hello my friend here it is the link
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=K8V-MX
to find and to download what you need
it is from asus official site so its secure,its from your mainboard,so just find exactly what tipe of downlaod you need..I suggest the user manual.youll find there the diagram for the case wires.
good luck.talk again if you need something
oh..rank my answer please..;)
thanks..
bye bye
Feb 05, 2008 | AMD Asus K8V-MX Socket...
Sata driver
check for the website of your HDD vendor.eg-www.seagate.com for seagate hdd.
make sure you format using fat32 file system.
Jan 28, 2008 | ASUS K8V-MX Motherboard
NEED FOR K8V MOTHREBOARD SATA DRIVER
there are 4 different k8v motherboard types, you didnt say which variant?
but you shouldnt need any 3rd party drivers, either the one built into the cmos, or the ones that are on the cd rom that comes with the motherboard should work fine with win2003.
they have always been fine on my installs, just ignore the question on the initial setup, its only asking incase you need to use one, you dont have to.
Oct 17, 2007 | ASUS K8V-MX Motherboard
ASUS K8V-X SE Motherboard Logo
144 people viewed this question
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
