Question about Radio Communications
How do I reset factory settings on icom ic41s UHF? Need to get rid of the T SQL on the screen as it blocks recieving messages. Only 1 channel does not have the T SQL logo showing up. Also to transmit I have to push talk button then push it again to stop transmitting
Posted by cflett786 on
David Edwards
T squelch and PTT on can be reset by button presses. It's shown in the manual, available for free online in various places.
Posted on May 04, 2020
5 Related Answers
Anonymous
  • 123 Answers
SOURCE: One way comm only
swap batteries if does not work this unit should need repair or replace, display blinking can be produced for power failure ( battery, contacts, circuits) or can be a controller issue.
Posted on Feb 14, 2008
eradiostore
eradiostore
  • 1658 Answers
SOURCE: Trouble transmitting & receiving on uhf.
While there might be a multitude of answers to this question. The first would be the radio is in need of repair, or not programmed correctly.
Posted on Jul 07, 2008
eradiostore
eradiostore
  • 1658 Answers
SOURCE: T5420 unable to transmit or receive. Please help!
Here is a link to the T5000-T5500 user manual. 'http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf'
From what you have stated, I can discern the radios will power up. You might try setting your interference eliminators to zero (off) to see if you are able to transmit at all.
You do not mention if you are using AA batteries or rechargeables. Either way a fresh set of charged batteries would be best for a test. It is clear you were getting power. However, it does take more energy to transmit than to receive. If your batteries are low or bad, pressing the PTT could us all the energy the radio has, and yet not transmit to the other units.
You might also check you VOX settings if any and be certain they are turned off.
It is not likely 4 radios would fail all at the same time. So it is probably a programming problem. Hope the user manual helps you find the solution.
Posted on Aug 24, 2008
eradiostore
eradiostore
  • 1658 Answers
SOURCE: t 5710 motorola talk about
Short of having a radio tech look at the radio, I would suggest looking at the grill and mic hole to see if there is dirt or debris blocking the hole.
Posted on Nov 16, 2008
eradiostore
eradiostore
  • 1658 Answers
SOURCE: Motorola Talkabout FV700 not transmitting nor receiving
To troubleshoot: Unlock your keypad lock, then reprogram your radios to the following settings. (Check function after each change)
1) Shut off the Interference Eliminator (set to zero).
2) Turn off the Qt filter.
3) Vox setting to off.
By shutting off all the "bells and whistles" of the radio, you will take it back to being just simply on a frequency. If your radios do not communicate with one another then, or with your friend's radios, you have radio which is failing to operate.
If the radios do work in this simple mode. One by one add the special features back until you discover the culprit.
Posted on Dec 26, 2008
How do i recieve uhf channels
If your television is fitted with a UHF tuner it should just be that you need to re-tune your set. This is often the case between seasons. If it is not fitted with one, then you need to buy and install a digital set top box to receive all stations, (Analogue, UHF and digital) in your area.
Oct 13, 2014 | Durabrand DWT1304 13" TV
How do I factory reset a oricome 200rx uhf
Factory reset
If the radio's display locks up or stops functioning properly, you might need to reset your UHF radio. Caution: this procedure clears all the information you have stored in your UHF radio.
Before you reset your UHF radio, try turning it off and on again. If your UHF radio is still not functioning correctly you may need to reset the UHF radio! While holding the F/DPX button, turn the UHF radio on. INITI AL will be displayed for 1 to 2 seconds, the radio will then return to its original display.
Oct 02, 2014 | Radio Communications
How can i do a factory reset on an icom ic-706, basically i want to clean it all off and have it like it came out the factory, it this possible??
Hi Paul,
The best I can come up with is Try this: join yahoo group Specific to your radio Make/Model, the experts there will help you with useful info and you can download manuals, schematics and software, if available, for your radio and all this is free.
I hope I have been of assistance to you.
Regards,
Peter
Nov 29, 2012 | ICOM Informatique Icom IC-F21 16ch UHF...
Static on radios not all time
hi by ajusting the squelch level in the menu you will solve this problem ,also check antenna connections aswell you might have to return them where you bought them to get them ajusted
goodluck
Apr 13, 2010 | ICOM Informatique 2nd radio Icom F221...
How to add frequencies/channels to ICOM IC-F21 two-way radios?
Sorry, but your radio is limited to 16 channels in the 400-430 and 440-470 MHz ranges. The number of channels cannot be expanded, nor can the frequency coverage.
Bill B
Mar 28, 2010 | ICOM Informatique Icom IC-F21 16ch UHF...
How do I reset the F221 to factory settings. I cloned the unit with V1.6 of the programming software with updates that included turning on the user start password and now the box will not communicate with...
F121 VHF, F221 UHF they both use the latest Version 1.7.
For F121 Factory default as follows:Open your CS-F100 software, enter RX TX frequency below, and write to the radio.Ch1: 136.100 MHzCh2: 155.100 MHzCh3: 173.900 MHz
For F221 Enter RX TX frequency belowCh1: 440.000MHzCh2: 460.000MHzCh3: 489.000MHz, then write to your radio
Or you check from this site:http://www.two-way-radio-tools.com/icom.html
HP
Feb 04, 2010 | ICOM Informatique IC-F121 VHF 136-174MHz...
My IC-F21 portable radio wont communicate with each other. is there a reset?
You will need the programming software to check all settings of the two radios. If both radios are programmed the same then you need to run tests on why they wont communicate to each other. Unfortunatly there is no "reset" for the radios. Carl
Jul 19, 2009 | ICOM Informatique Icom IC-F21 16ch UHF...
I have a black rectangle covering the center of the screen from top to bottom. How do I get rid of it? I tried the menu for Closed Captioning but it did not seem to work.
Try turning off the closed caption and text also check v chip, if you have a channel or channels blocked it could cause a black rectangle to pull up on the screen, if that doesn't work try resetting the unit to factory settings
Jun 16, 2009 | Toshiba 50HP66 50 in. Plasma Television
Programming an Icom IC R5 scanner
This is a problem with any scanner which has no keypad..
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
Dec 22, 2008 | Icom IC-R5 Handheld Scanner
What's the channel frequencies for a common 22 channel motorola 2 way vhf radio?
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats  the case you will need an Icom that will do UHF freqs.
Oct 12, 2007 | Unwired UFR650 (14 Channels) 2-Way Radio
Radio Communications Logo
802 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
