Question about Canon Digital SD900 / IXUS 900 Ti Digital Camera
My camera any information "lens
Posted by yulian_045 on
CameraR
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Posted on Jul 17, 2011
Lens error
"Lens error, restart camera". Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here's an article and here's a video that shows some things that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Ge c1033 digital camera having problem as when power on camera its lens on and off and shows error "lens Obstruction restart camera" please help me resolve it.
My camera (canon PoweShot SD660) in giving me an error that reads, "lens error, restart camera" and it turns off. How do I fix it?
Lens error on cannon powershot sd600. When I turn it on it gives me a "lens error, restart camera" and it turns off.
When i want to turn on the camera , a massage comes as below "lens error restart camera " . i did several time but still there is problem .what should i do?
Unfortunately, restarting the camera rarely corrects a lens error problem. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
I was getting some good high footage on my tripod with my Canon SD940 digital camera and the lens hit the ground. When I tried restarting my camera, it showed my splashscreen and then said "Lens...
I turned on my camera as normal to take a picture and the lens came out as normal but then the camera "turned off" with the lens still in the ready positon and a error message appeared on the...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Canon Digital SD900 / IXUS 900 Ti Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Ekse
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
