Question about Compaq Computers & Internet
I have download a movie from xvid and burned it to a dvd-r disc but it won't play in my magnavox dvd player. it keeps reading disc error on tv screen. what should i do?
Posted by j_toya67 on
Nanny
    Genius:
  • Compaq Master
  • 2,351 Answers
Normally you cannot directly put some video files to a regular DVD player. You need to convert and burn these video files such as Xvid to DVD and then you can play them on DVD players.
Make sure you a blank disc with enough space to store the video and the disc drive for you to insert the disc. Then you need a burning program to convert Xvid to DVD. Here are some burning programs for your reference:
Leawo DVD Creator
It supports more than 180 formats. Videos in formats like AVI, MKV, MP4, WMV, Xvid, MOV, and FLV can be burnt to DVD-9 and DVD-5 discs. It can create DVD with high speed and high quality.
DVDStyler
It allows not only burning of video files on DVD that can be played practically on any standalone DVD player, but also creation of individually designed DVD menus.
DeVeDe
DeVeDe is a Linux-only DVD authoring solution that requires a minimal amount of dependencies to do its job. DeVeDe supports a large range of formats
Posted on Apr 10, 2019
ABRAR
    New Friend:
  • 36 Answers
Format data coded not supported
convert it through a converter software . eg,XVID TO VOB.EXE or MPEG it will work
Posted on Jul 16, 2011
Why doesn't my recorded dvd-r movies play on my magnavox dvd player
Does your DVD player support that version of DVD disk? Not all players will handle DVD-R. Check the manual for compatibility.
Try recording to DVD+R then see if your player will play it.
Also, in what format (.avi, .flv, .mov, etc.) was the item recorded and is your player able to handle that format? Again, check the manual for compatibility.
Jan 20, 2015 | Funai FDRV90E DVD Recorder/VCR
Recorded pictures onto a DVD on my computer, they won't play on the ZV420mw8
I looked up your DVD player's model number online. It is not equiped to read picture files (.jpg, .bmp, etc.) You have to be carefull when you transfer pictures to a DVD on your computer. If you just burn them to the disc, most DVD players wont be able to read the information. Frequently you have to use a program like Microsoft Movie Maker to get them in the right format.
You may have to start over and use a DVD making program to make them a video and not just picture files.
Hope this helps! Don't forget to rate!
Jun 26, 2012 | Magnavox ZV420MW8 DVD/VCR
Dvd-l200
It depends how you burn movies (for example). If you burned as data disc, it's probably won't play it. Make sure you burn movies as DVD format.
May 19, 2012 | Samsung portable dvd player DVD-L200 User...
Magnavox MPD850 dvd player won't play, only display no disc
The problem is in the laser pickup assembly, over time the laser becomes weak until it can no longer read the disc, but you can buy a DVD cleaning kit that might breath more life into the player, if no! cheaper to replace the DVD player.
Mar 17, 2012 | Magnavox Televison & Video
Getting a C 13 70 disc is dirty message only for DVDs that I'e burned recently. I bought a new pack of blank DVDs, the same kind I've always used, but every movie I burn on these new ones, they...
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Nov 03, 2011 | Sony DVP-SR200P DVD Player
Do I need a remote control to control the Philips magnavox model DVD 815AT. It plays the commercials on the video disc. When it comes to playing the movie, it keeps repeating itself and it won't go...
Usually most DVD's play movie trailers and sometimes advertisement before the movie will play. Once the ads or trailers are done it should go to the menu screen and at that point "play" or something like that should be underlined. If it is you can press play or select on the DVD player then the movie should start : )
Jul 27, 2011 | Philips DVD815AT DVD Player
Magnavox NB500MG9 BluRay Player
A Blu-ray player can play DVD or CD and still not play Blu-ray. It may play Blu-ray but not CD or DVD, or burned discs. This is all caused by the 'optical' a part that reads the disc in the machine. Your player will need service as a Blu-ray optic cannot just be 'dropped' into a player.
Mar 28, 2010 | Magnavox NB500MG9 BluRay Player
Disc error "playback feature may not be available on this disc"
Hello arnita2211,
This error message is due to an improper format, that your dvd player can't handle. To correct this you need to use a program such as nero and in nero is a program called nero vision, that will recode the movie file into a dvd playable format.
You can download a trial of nero here
http://www.nero.com/enu/downloads-nero9-trial.php
You will have to purchase a license when the trial ends. Sorry we cannot give you a serial key for this as it is Illegal.
Thank you for trying Fixya!
Apr 08, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD movie onto a CD-RW
first off, your not going to get dvd quality on cd, if ur talking about a standard dvd that u wish to put on cd, dont even bother.
4GB(DVD) to 700MB(CD) ? re-encoding it to that size will look like crap.
enjoy
Feb 28, 2008 | Televison & Video
Computers & Internet Logo
101 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Toby Lee
Toby Lee
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
