Question about Home
Is window foam the best thing to put under shower for support
Posted by ksittre on
Paul Aragosa
    Problem Solver:
I used window foam under my shower stall installed in my basement back in 1988 and still maintaining a firm support for the shower stall Floor. I did have to reseal the drain with plumbers putty this year. In my walk through life I spent most of it in all areas of construction now Retired Clerk Of The Works / On Site Engineer In Charge after almost 30 yrs on the job. I am and always have been a user of expansion foam for correcting or utilizing it as a versitle material for construction.
Posted on Aug 19, 2011
Paul Beyer
  • 528 Answers
No it will collapes
Posted on Jul 16, 2011
How do I unclog my tub?
Put a cup of Baking Soda in drain, then add two cups white vinegar! This should foam like crazy wait ten minutes ,run real hot water.
you may have to repeat a couple times.
this will not hurt pipes unlike some drain cleaners.
Oct 02, 2016 | Moen & One Handle Tub & Shower Faucet
Where to buy aariel steam shower 120V 3kw heating element
best thing i could advise you to do is go to their web site and order direct...this is your best bet...good luck
Dec 26, 2012 | Dmm WMK-A06 Pearl Steam Shower Unit,...
Can the styrofoam insulation in our air conditioner be replaced or patched?
Yes it can but you will have to use expandable foam. You must shape it after it drys. Old trick, works like a charm. Should be an under $5 repair
May 29, 2012 | Whirlpool ACQ158XP Wall/Window Air...
I have a neptune shower. Solo. when I put the shower on it runs for about 2 mins then just switches of if I then wait for about 5 minutes it comes back on but still does the same thing
remove the low flow guts (if possible) in it and give it a try, these low flow filters have created issues like this many times..
Best regards
Ck
Jul 28, 2011 | Home
Occasionally my Saniplus pump runs but doesn't drain. It seems to happen when there is a moderate amount of bubbles created. i.e. when I have showered with a shower gel and the gel foams up to create...
This sounds as if you have a venting problem if there is no air introduced into system then it cannot drain,even with a pressure pump system,the only other thing is that the pump and grinder system is faulty,if still under warranty contact mftr.
Jun 19, 2011 | Saniflo 002/005/007 Saniplus Toilet with...
Install plastic (fibreglass)shower floor tray. Do
no, they are designed to require no support. You may use small columns of expansion foam for added strength, but do not fill entire space with foam as it will raise the whole floor upon expansion.
Sep 22, 2010 | Home
I have just had a new shower enclosure fitted which has has to be built up off the floor to allow for drainage. This has left a 3" gap along the bottom from floor to shower base. Where can I get a piece of...
Hello. Just go to home depot or lowes and get 2-3 spray cans of expandible foam. If you have acces to the opening between the floor and shower floor spray it around the gap. If not, Just use a small drill bit and make some holes around the wood frame and spray it. These foam will secure the shower and also will prevent the shower floor to crack it.
Aug 30, 2010 | Home
What product should i use to put under my shower base before i set it. that would make the base feel more solid.
The foaming polyurethane in a can (usually referred to as "Great Stuff") is a really good solution here. Just spray it on the floor and quickly set your base, or if possible and the sheetrock is not on you can set the shower and reach in under it and foam
Nov 04, 2009 | Home
Water comes out the shower head without the faucet lever being engaged
the whole faucet is bad it has an internal leak replace the whole thing
Jul 03, 2009 | Home
Home Logo
150 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
