SOURCE: Hotpoint ultima wt741 F11 fault code
HI
There are several reasons why a Hotpoint door could be jammed shut. One
of them is the part you describe which is called the ******. With some
older Hotpoint models, there is a cable that runs from the door
interlock to the motor. When you operate the door catch or button, this
part "pecks" down onto the drive belt or the end of the armature's
shaft. If the drum is moving, the ****** will slip on the rotating belt
or armature and disengage the door interlock. If the drum is not
moving, the ****** meets resistance and the door opens. Therefore if
the ****** has come off, or is loose, it can stop the door opening.
When you attempt to open the door does this part move?
Other things that can stop the door opening are -
Thank you
SOURCE: Filter on WT960
hi, in the uk the filter is behind a flap on the bottom/front of the machine, be careful as when you undo it some water will leak out, hope this helps
SOURCE: hotpoint wdd960 washer dryer error f05
f05 means blockage and cannot drain-switch off at mains to reset error-turn to drain if pump runs but dont drain filter in sump blocked/if no pump action then somthing is jammed inn pump
SOURCE: how do I find the filter on the Hotpoint Ultima
If I am right this machine is fitted witha self cleaning pump and does not have a filter. If there is no filter under the kickstrip then this is correct. many Hotpoints are now made this way but yiu may still have one so check under the kickstrip.
SOURCE: how do i change the language on my washing
Press and hold the drying,delay start/temp select buttons altogether for 5 sec untill you hear a beep, then release all 3. press the dely start button to scroll through the available languages then select your chosen language by pressing the drying button once.
