Without knowing what Model Number of MAC G4 you're referring to, I can only give you generic information.
If your MAC G4 has a DVI port it is generally the female style.
The DVI connector on the adapter will need to be a male DVI style.
The VGA end of the adapter will be either male, or female. Most VGA connectors on a monitor cable have a male VGA end.
(The DVI end will have the pins sticking out on the adapter. The VGA end will have the socket holes)
Also stated as the monitor cable end will be a DVI male. The port {Connection} on the computer is a VGA female)
Example of a DVI male to VGA female adapter,
http://sewelldirect.com/dviaftovgam.asp
Barring that you need the other style of DVI to VGA adapter, (DVI female on the monitor cable, VGA male on the computer), this is an example,
[ Note* The newer VGA connectors are also known as an HD-15 connector.
More information on the Video Graphics Array connector,
http://en.wikipedia.org/wiki/VGA_connector
More information on the DVI connector styles, and the Digital Visual Interface technology,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If you should find all of this confusing, simply state in a Comment as to what connector is on the end of the monitor cable, and what connector is at the computer.
State whether the connectors are Male (Pins sticking out), or Female (Socket holes)
Regards,
joecoolvette
Edit:
Flubbed that one up digger100.
DVI female to VGA male adapter,
"Barring that you need the other style of DVI to VGA adapter, (DVI female
http://www.directron.com/dvi.html
