Question about Dell W3000 30 in. HD-Ready LCD Television
Dell W3000 LCD TV has sound but no picture. In the past have had to turn on and off several times but this no longer works.
Posted by rwunsch25 on
John Pritchett
    New Friend:
The problem of the picture not firing up right away on the Dell w3000 display is a manufacture defect in the LCD Inverter Boards. Could be master and could be slave that's failing. Most likely Master, but I suggest replacing both master and slave just to be sure. Stay away from pulled parts sold on ebay for this fix. You'll just be buying the same problem most likely. Try http://www.lcdparts.net/InverterDetail3D.aspx?ProductID=1921 I have ordered from them in the past they are reliable and handle RMA's quickly. This is a huge plus if you run into another problem trying to replace. They want 149.00 and the fix requires very little skill level to replace. Just have to decide if 149 bucks is worth it, or is it time to go for the 50 inch. hmnmm. Good Luck,
John Pritchett
Posted on Oct 22, 2011
W3000, power and audio but not picture
Yes I tried it and now I have nothing, not even a green light. So much for that. I have 2 of these sets. If you never unplug them from 110 I never have a problem. Un plug them and wait 2-3 days and nothing.
Any lawyers what to take this on?
Jul 08, 2009 | Dell W3000 30 in. HD-Ready LCD Television
HELP
mainboard is bad and needs replaced with the proper rev and firmware updates. questions, email me
Oct 27, 2008 | Dell W1700 17 in. HD-Ready LCD Television
Dell w3000
Don't buy Dell TV's. I have been fighting this problem for years.
A royal pain. Now there is no red in the picture. All blue and beige.
My solution? New TV and ABSOLUTELY NO DELL!!!
Aug 11, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Weak sound from Dell W3000
Its possible that the speakers that came with the TV aren't amplified. Do you have another set of speakers that are to test the audio output?
Jul 26, 2008 | Dell W3000 30 in. HD-Ready LCD Television
DEL lcd W3000
Here is my suggestion.. sell it to me.. or I can ship you a new power board, a typical problem with these units. I have several power boards in stock (new). They are $129 each. If you are interested, email [email protected].
May 20, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Dell tv w3000
Try turning the master power on and off a few times. Give it a few secs inbetween power offs and that should work. It's worked for me. Sometimes it takes longer that other times to show a picture.
Nov 28, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Dell w3000 has green power on no video just audio only
Had same problem as described by others, green light, audio, but no picture. Decided to look inside. Layed the TV face down on three textbooks (1 at top & 1 at left & Right) so that back (9 large screws & 2 small screws) could be removed along with stand. From the power supply (board that 110v AC plugs into) there is a cable connected to a circuit board on the left (again looking from the back of the TV) covered by metal shielding. Unplug this cable clean the male contacts with a miniture wire brush (bought mine at Home Depot) & plug the cable back into the socket. With rubber gloves (just to be safe) plug the AC cord into the back of the TV & wall and turn on your TV. The bulbs should activate in 7 - 8 seconds. Reassemble the back of the TV & install the stand. Enjoy your TV Doug
Sep 08, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Dell W3000 30 in. HD-Ready LCD Television Logo
111 people viewed this question
Top Dell Televison & Video Experts
CoppellTVRepair.com
Marvin
Marvin
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
